Salta al contenuto principale
Anne Pro 2 Keyboard Keycaps Replacement
Cosa ti serve
  1. Anne Pro 2 Keyboard Keycaps Replacement, Keycaps: passo 1, immagine 1 di 1
    • Set the keyboard down on a flat surface. Make sure it is turned off and is not connected to a power source.
  2. Anne Pro 2 Keyboard Keycaps Replacement: passo 2, immagine 1 di 3 Anne Pro 2 Keyboard Keycaps Replacement: passo 2, immagine 2 di 3 Anne Pro 2 Keyboard Keycaps Replacement: passo 2, immagine 3 di 3
    • Use the keycap remover to remove the key caps from left to right.
    • Remove the smaller keycaps first so the surrounding larger caps can be removed more easily.
  3. Anne Pro 2 Keyboard Keycaps Replacement: passo 3, immagine 1 di 2 Anne Pro 2 Keyboard Keycaps Replacement: passo 3, immagine 2 di 2
    • Use the compressed air to remove all dust and hair from the keyboard.
    • Focus on the red key switches to make sure all dust and hair are removed from inside.
  4. Anne Pro 2 Keyboard Keycaps Replacement: passo 4, immagine 1 di 1
    • New replacement keycaps can be used here, but if you see no damage to older keycaps they can be re-used.
    • Use the keycap remover to set in the keycaps starting from the bottom to the top.
  5. Anne Pro 2 Keyboard Keycaps Replacement: passo 5, immagine 1 di 1
    • Inspect the final product, making sure all keycaps are back in the right place and functioning.
Linea Traguardo
Omar Sukkar
Membro da: 11/24/20
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,941
