Salta al contenuto principale
Anne Pro 2 Case/Housing Replacement
Cosa ti serve
  1. Anne Pro 2 Case/Housing Replacement, Case/Housing: passo 1, immagine 1 di 3 Anne Pro 2 Case/Housing Replacement, Case/Housing: passo 1, immagine 2 di 3 Anne Pro 2 Case/Housing Replacement, Case/Housing: passo 1, immagine 3 di 3
    • Unplug the Anne Pro 2 Keyboard.
    • Turn off the Anne Pro 2 Keyboard using the switch on the bottom.
  2. Anne Pro 2 Case/Housing Replacement: passo 2, immagine 1 di 2 Anne Pro 2 Case/Housing Replacement: passo 2, immagine 2 di 2
    • Using a keycap remover, remove the the following keycaps: Left Alt, Space Bar, Right Shift, Backslash, Y, H, and the Tab key.
  3. Anne Pro 2 Case/Housing Replacement: passo 3, immagine 1 di 2 Anne Pro 2 Case/Housing Replacement: passo 3, immagine 2 di 2
    • Using a Torx T5 bit, remove the five screws from the keyboard.
  4. Anne Pro 2 Case/Housing Replacement: passo 4, immagine 1 di 2 Anne Pro 2 Case/Housing Replacement: passo 4, immagine 2 di 2
    • Lift the keyboard slowly from the bottom side.
    • Do not fully lift the PCB because the battery is still plugged in.
  5. Anne Pro 2 Case/Housing Replacement: passo 5, immagine 1 di 2 Anne Pro 2 Case/Housing Replacement: passo 5, immagine 2 di 2
    • Gently unplug the battery connector by wiggling it back and forth.
  6. Anne Pro 2 Case/Housing Replacement: passo 6, immagine 1 di 2 Anne Pro 2 Case/Housing Replacement: passo 6, immagine 2 di 2
    • Remove the PCB from the main case.
    • Gently lower the PCB into the Zero-Degree housing from the top side first.
    • Firmly press it in once you have lowered it.
  7. Anne Pro 2 Case/Housing Replacement: passo 7, immagine 1 di 2 Anne Pro 2 Case/Housing Replacement: passo 7, immagine 2 di 2
    • Screw the five T5 Torx screws back into place.
  8. Anne Pro 2 Case/Housing Replacement: passo 8, immagine 1 di 2 Anne Pro 2 Case/Housing Replacement: passo 8, immagine 2 di 2
    • Take the seven keycaps you removed and gently place them in their intended spots on the keyboard.
    • Firmly press them in, ensuring they are flush with the rest of the keys.
Conclusione
Altre 2 persone hanno completato questa guida.
Mohamed
Membro da: 09/15/20
205 Reputazione
1 Guida realizzata
Un commento
Anne Pro 2 Software manage the illumination, open the mobile App and choose a pre-programmed scheme or design your own pattern, with a distinct colour for each key if desired. The programmes are easy to use and work on both Mac and PC.
Visit Here-   https://www.techtoreview.com/top-picks/a...
Abhinav Pal - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 137
Tutti i Tempi: 10,042
