Salta al contenuto principale
Anklet Charm Replacement
Cosa ti serve
  1. Anklet Charm Replacement, Charm: passo 1, immagine 1 di 2 Anklet Charm Replacement, Charm: passo 1, immagine 2 di 2
    • To start, decide where on the chain you wish to place the charm. Thread the headpin through the chain link, and then place the charm on the headpin next to the chain.
  2. Anklet Charm Replacement: passo 2, immagine 1 di 1
    • Bend the head pin in half, with the chain and charm at the apex of the bend.
  3. Anklet Charm Replacement: passo 3, immagine 1 di 1
    • Cross the head pin to create a loop. Pull as tightly as possible.
  4. Anklet Charm Replacement: passo 4, immagine 1 di 1
    • Use round nose pliers and your hands to twist the head pin, closing off the loop. Make the twists as tight as possible. Twist 2-4 times.
  5. Anklet Charm Replacement: passo 5, immagine 1 di 1
    • Use semi-flush side cutters to cut the extra length off of the head pin.
  6. Anklet Charm Replacement: passo 6, immagine 1 di 1
    • Use round-nose pliers to fold the twisted head pin so it is flush with itself.
  7. Anklet Charm Replacement: passo 7, immagine 1 di 1
    • Finished!
Conclusione
Helene Hartfield
Membro da: 07/27/20
145 Reputazione
1 Guida realizzata
UW Tacoma, Team S1-G4, Cardinal Summer 2020 Membro di UW Tacoma, Team S1-G4, Cardinal Summer 2020
UWT-CARDINAL-SU20S1G4
1 Membro
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,106
