Salta al contenuto principale
Anki Vector Belts Replacement
  1. Anki Vector Belts Replacement, Belts: passo 1, immagine 1 di 1
    • Raise Vector's arms above his head.
  2. Anki Vector Belts Replacement: passo 2, immagine 1 di 2 Anki Vector Belts Replacement: passo 2, immagine 2 di 2
    • Using your thumb and index finger, grab the lower portion of the belt near the large wheel and pull the belt off.
    • Repeat on the other side.
Conclusione
Shay Takei
Membro da: 04/16/19
1.663 Reputazione
5 Guide realizzate
Cal Poly, Team S2-G6, Maness Spring 2019 Membro di Cal Poly, Team S2-G6, Maness Spring 2019
CPSU-MANESS-S19S2G6
4 Membri
10 Guide realizzate
Un commento
Anki statement on the consumer robotics company shutting down. ... Vector also used the cloud to get smarter over time via machine learning, Anki said. Customers on Anki Developers Forum are reporting that Vector is still alive and well. Of course, this could all change over time, which is exactly what we saw with Jibo.
PrestoStore - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,273
