Salta al contenuto principale
Anker Soundcore Life Q30 Earphone Cushion Replacement
Cosa ti serve
  1. Anker Soundcore Life Q30 Earphone Cushion Replacement, Earphone Cushion: passo 1, immagine 1 di 2 Anker Soundcore Life Q30 Earphone Cushion Replacement, Earphone Cushion: passo 1, immagine 2 di 2
    • Orient the headphones such that the headphone speakers are closest to you, and the headband is furthest from you.
    • Adjust the folding hinge to where the speakers are facing up.
    • Make sure you can easily reach the edge where the cushion connects to the rest of the headphones.
  2. Anker Soundcore Life Q30 Earphone Cushion Replacement: passo 2, immagine 1 di 3 Anker Soundcore Life Q30 Earphone Cushion Replacement: passo 2, immagine 2 di 3 Anker Soundcore Life Q30 Earphone Cushion Replacement: passo 2, immagine 3 di 3
    • Using one hand, hold the right side of the headphones still.
    • Using your other hand, slide the plastic opening tool in the edge along the cushion.
    • Gently pry the cushion off using the plastic opening tool.
    • Set the right ear cushion aside and repeat this step for the left side of the headphones.
  3. Anker Soundcore Life Q30 Earphone Cushion Replacement: passo 3, immagine 1 di 2 Anker Soundcore Life Q30 Earphone Cushion Replacement: passo 3, immagine 2 di 2
    • Remove the white foam pieces from the old cushions, noting their orientation.
    • Insert the white foam pieces from the old cushions into the replacement cushions. Make sure to set them in the same orientation they were in previously.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 69
Ultimi 30 Giorni: 184
Tutti i Tempi: 362
