Introduzione
This guide will show you how to replace the battery in the Anker Soundcore Life Q30 headphones. The battery is what allows power and charge through the headphones, so a faulty battery can cause the headphones to become weak or not turn on at all. Replacing this will require you to resolder the replacement battery to the circuit board. Before you begin, make sure to turn off the headphones and unplug them from their charger.
Cosa ti serve
Orient the headphones such that the headphone speakers are closest to you, and the headband is furthest from you.
Adjust the folding hinge to where the speakers are facing up.
Make sure you can easily reach the edge where the cushion connects to the rest of the headphones.
Using one hand, hold the right side of the headphones still.
Using your other hand, slide the plastic opening tool in the edge along the cushion.
Gently pry the cushion off using the plastic opening tool.
Set the right ear cushion aside and repeat this step for the left side of the headphones.
Pull the microphone (circular blue part) from its socket by the connected red wire that is covered in black rubber.
Unscrew the four 5.7 mm screws with a Phillips #00 screwdriver connecting the earcup to the headphone’s frame.
Remove the earcup.
From here, you’ll have to solder your replacement battery into place. After doing so, follow these steps in reverse order to reassemble the device.
