Salta al contenuto principale
Anker 2.4G Wireless Mouse Left and Right Button Replacement
Cosa ti serve
  1. Anker 2.4G Wireless Mouse Left and Right Button Replacement, Left and Right Buttons: passo 1, immagine 1 di 1
    • Peel off the stickers. This will reveal the location of four screws.
  2. Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 2, immagine 1 di 1
    • Remove the four screws using a Phillips #0 screwdriver.
  3. Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 3, immagine 1 di 2 Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 3, immagine 2 di 2
    • Use a spudger to pry apart the upper and lower housing of the mouse.
  4. Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 4, immagine 1 di 1
    • Pull the wires from the white crimping headers to disconnect them. This separates the top housing from the bottom housing.
    • Pull as far up on the wires as possible. Be careful not to rip the wires by applying too much force.
  5. Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 5, immagine 1 di 1
    • Remove the scroll wheel from the mother board by pulling it to the left.
    • This may take some force to remove. Make sure to pull the scroll wheel parallel to the board, not perpendicularly.
  6. Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 6, immagine 1 di 1
    • Pull the mother board gently away from the plastic housing.
  7. Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 7, immagine 1 di 2 Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 7, immagine 2 di 2
    • Desolder the components and re-solder the replacements in order to repair the left and right buttons.
Conclusione
Altre 2 persone hanno completato questa guida.
Vincent Lee
Membro da: 01/23/14
361 Reputazione
3 Guide realizzate
Cal Poly, Team 1-39, Maness Winter 2014 Membro di Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 Membri
16 Guide realizzate
2 Commenti
i bought the same mouse on amazon the same day i got it stopped working and anker was out of stock so i couldn't get another one directly from them, plus i really like it i opened up the mouse using your step by step and found the issue.
jacques gates - Replica
where can these replacement button switches be purchased….thanks ric
Ric Scambler - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 4,590
