Salta al contenuto principale
Anker 2.4G Wireless Mouse LED Replacement
Cosa ti serve
  1. Anker 2.4G Wireless Mouse LED Replacement, LED: passo 1, immagine 1 di 1
    • Use a spudger to gently pry off the stickers to reveal the location of the four screws.
  2. Anker 2.4G Wireless Mouse LED Replacement: passo 2, immagine 1 di 1
    • Remove the four screws to continue.
  3. Anker 2.4G Wireless Mouse LED Replacement: passo 3, immagine 1 di 2 Anker 2.4G Wireless Mouse LED Replacement: passo 3, immagine 2 di 2
    • Pry the center of the mouse apart using a spudger to separate the upper and lower housing of the boards.
  4. Anker 2.4G Wireless Mouse LED Replacement: passo 4, immagine 1 di 1
    • Remove the wires from the white crimp headers. This will separate the upper and lower housing units of the mouse.
    • Pull as far up on the wire as possible, but be careful to avoid ripping the wires.
  5. Anker 2.4G Wireless Mouse LED Replacement: passo 5, immagine 1 di 2 Anker 2.4G Wireless Mouse LED Replacement: passo 5, immagine 2 di 2
    • Take the upper housing of the mouse and remove the two screws that hold the board in place.
  6. Anker 2.4G Wireless Mouse LED Replacement: passo 6, immagine 1 di 1
    • Gently remove the circuit board from the mouse.
  7. Anker 2.4G Wireless Mouse LED Replacement: passo 7, immagine 1 di 1
    • To remove the LED, flip the board over and desolder the wires.
    • Replace LED with a new LED and resolder into place.
Conclusione
Colin
Membro da: 02/10/14
406 Reputazione
3 Guide realizzate
Cal Poly, Team 1-39, Maness Winter 2014 Membro di Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,920
