Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
  1. Use screwdriver to pry off the stickers marked in red to reveal the location of the 4 screws.
    • Use screwdriver to pry off the stickers marked in red to reveal the location of the 4 screws.
  2. Remove the 4 screws to continue.
    • Remove the 4 screws to continue.
  3. Pry the center of the mouse apart to separate the upper and lower housing of the boards. Pry the center of the mouse apart to separate the upper and lower housing of the boards.
    • Pry the center of the mouse apart to separate the upper and lower housing of the boards.
  4. Remove the wires from the white crimp headers. this will separate the upper and lower housing units of the mouse.
    • Remove the wires from the white crimp headers. this will separate the upper and lower housing units of the mouse.
    • Pull as far up on the wire as possible, being as careful as possible to avoid ripping the wires.
  5. Take the upper housing of the mouse and begin to remove the two screws (highlighted in red) that hold the board in place. Take the upper housing of the mouse and begin to remove the two screws (highlighted in red) that hold the board in place.
    • Take the upper housing of the mouse and begin to remove the two screws (highlighted in red) that hold the board in place.
  6. Gently remove board.
    • Gently remove board.
  7. The DPI button is the red push button highlighted in red. To remove it, flip the board over and desolder the wires highlighted in orange.
    • The DPI button is the red push button highlighted in red.
    • To remove it, flip the board over and desolder the wires highlighted in orange.
    • Replace component with new component and resolder back in place.
Conclusione
Colin
Membro da: 10/02/2014
367 Reputazione
3 Guide realizzate
Cal Poly, Team 1-39, Maness Winter 2014 Membro di Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,369
