Salta al contenuto principale
Angelcare AC401 Baby Monitor Disassembly
Cosa ti serve
  1. Angelcare AC401 Baby Monitor Disassembly, Angelcare AC401 Baby Monitor Disassembly: passo 1, immagine 1 di 2 Angelcare AC401 Baby Monitor Disassembly, Angelcare AC401 Baby Monitor Disassembly: passo 1, immagine 2 di 2
    • first remove the 2 screws at the green plastic plate.
  2. Angelcare AC401 Baby Monitor Disassembly: passo 2, immagine 1 di 1
    • remove the plastic plate ( battery compartment)
    • you'll see that there are 2 more screws. Remove them.
  3. Angelcare AC401 Baby Monitor Disassembly: passo 3, immagine 1 di 2 Angelcare AC401 Baby Monitor Disassembly: passo 3, immagine 2 di 2
    • now gently remove the green plastic plate arrounf the baby monitor ( arround the screen) use a spudger to click it open.
  4. Angelcare AC401 Baby Monitor Disassembly: passo 4, immagine 1 di 2 Angelcare AC401 Baby Monitor Disassembly: passo 4, immagine 2 di 2
    • now open the monitor by clicking it open or slide it open. Sometimes its easier to use a spudger.
    • be carefull for the electric wires.
  5. Angelcare AC401 Baby Monitor Disassembly: passo 5, immagine 1 di 2 Angelcare AC401 Baby Monitor Disassembly: passo 5, immagine 2 di 2
    • 2 battery's were exploded so the acid was on the black electric power wire.
    • use a cotton swab with a little bit of destilled water.
  6. Angelcare AC401 Baby Monitor Disassembly: passo 6, immagine 1 di 1
    • remove the 2 PCB's by removing the screws shown in the picture.
  7. Angelcare AC401 Baby Monitor Disassembly: passo 7, immagine 1 di 1
    • pull the first PCB up and remove the screws of the second PCB.
    • after removing the two PCB's, clean the acid on the PCB.
    • after cleaning the PCB's put it al together again.
    • first remove the battery lid. 1 screw.
    • slide it out like you see in picture
    • remove battery's
Conclusione
Altre 6 persone hanno completato questa guida.
Kevin D
Membro da: 05/02/14
7.316 Reputazione
21 Guide realizzate
13 Commenti
Thanks for this. I couldn't figure out how to get the blue clip off without breaking it to clean some dirt on the screen. Googled it, found this, job done.
Pete H - Replica
Sometimes the activity of the reference quartz is 11,150 MHz, and the devices do not find each other.
I have so repaired the parent module.
Dmitriy, the city of Volzhsky.
Dmitriy N - Replica
Hi Dimitriy - I am experiencing the issue with not finding devices each other. How have you fix it ? Is it a matter of replacing the reference quartz with new one ?
Jan - Replica
Hi. At my Angelcare (AC401) parent unit the screen has slowly become worse and worse. At first, parts of the temperature figures dissapeared, then the symbols around and now I no longer see anything... But the unit still works! (And alert me if the baby's crying) What do you think, is there anything I can do or do I need to buy a new one?
Terese Rehn - Replica
Hi There. I’m having the same problem. Did you find a fix or did you buy a new unit?
Eugene -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 27
Tutti i Tempi: 14,919
