Salta al contenuto principale
Android tablet Nobis NB09 Screen Replacement
Cosa ti serve
  1. Android tablet Nobis NB09 Screen Replacement, Screen: passo 1, immagine 1 di 3 Android tablet Nobis NB09 Screen Replacement, Screen: passo 1, immagine 2 di 3 Android tablet Nobis NB09 Screen Replacement, Screen: passo 1, immagine 3 di 3
    • Remove the two 00 Phillips screws located on the right side of the tablet.
    • Use the plastic opening tools to loosen and then pry the back if the tablet off.
    • When prying off the back of the tablet, be careful around the tablets ports. Too much pressure can cause cracks.
  2. Android tablet Nobis NB09 Screen Replacement: passo 2, immagine 1 di 3 Android tablet Nobis NB09 Screen Replacement: passo 2, immagine 2 di 3 Android tablet Nobis NB09 Screen Replacement: passo 2, immagine 3 di 3
    • It is recommended that a grounding bracelet be used in order to avoid damage to the device's circuits through ESD (Electro-Static Discharge)
    • Remove the electrical tape covering the motherboard.
    • Remove the four 4.0 mm T4 Torx screws holding the motherboard to the front half of the tablet.
    • Remove any remaining adhesive tape on the exposed area.
    • Disconnect the ribbon cable attachments by lightly pushing up the locking arm (black tab) on each then gently detaching the pin connectors.
  3. Android tablet Nobis NB09 Screen Replacement: passo 3, immagine 1 di 3 Android tablet Nobis NB09 Screen Replacement: passo 3, immagine 2 di 3 Android tablet Nobis NB09 Screen Replacement: passo 3, immagine 3 di 3
    • Find the notch on the digitzer, located on the left side of the device.
    • Use the Phillips Screwdriver to gently push the notch and lift the digitizer from the screen.
  4. Android tablet Nobis NB09 Screen Replacement: passo 4, immagine 1 di 3 Android tablet Nobis NB09 Screen Replacement: passo 4, immagine 2 di 3 Android tablet Nobis NB09 Screen Replacement: passo 4, immagine 3 di 3
    • Gently slide the digitizer from its clasps to remove it from the screen.
    • The digitizer should now be removed separately from the screen.
Conclusione
Altre 4 persone hanno completato questa guida.
Enea Osmann
Membro da: 10/31/14
158 Reputazione
1 Guida realizzata
2Commenti sulla guida
The digitizer replacement instructions was great. Thanks
steven warren - Replica
My screen is busted that has the sensor in it do I have to buy a screen or can I use a keyboard?
April sharp - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,598
