Salta al contenuto principale
Andoer HDV 107 Battery Replacement
  1. Andoer HDV 107 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • At the bottom of the camera you will see the battery compartment cover as seen in the picture.
    • To open this compartment, apply pressure in the direction of the arrow and remove.
  2. Andoer HDV 107 Battery Replacement: passo 2, immagine 1 di 1
    • You will see the battery being held in place by a clear plastic kickstand.
    • Use your finger to move the kickstand away from the battery.
  3. Andoer HDV 107 Battery Replacement: passo 3, immagine 1 di 1
    • With your other hand press down on the battery slightly and remove the battery.
    • If the battery does not come out right away try to line the battery up with the sides to give it a clear path out of the compartment.
Conclusione
Isaac Saron
Membro da: 03/20/17
516 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 348
