Salta al contenuto principale
Anbernic RG 40XXV Shoulder Button Replacement
Cosa ti serve
  1. Anbernic RG 40XXV Shoulder Button Replacement, Back Panel Assembly: passo 1, immagine 1 di 3 Anbernic RG 40XXV Shoulder Button Replacement, Back Panel Assembly: passo 1, immagine 2 di 3 Anbernic RG 40XXV Shoulder Button Replacement, Back Panel Assembly: passo 1, immagine 3 di 3
    • Remove the micro SD card located on the left and right sides of the device by pushing into the SD card slot and pulling the card out.
    • Unscrew all six 7.5 mm screws on the backside of the case using a 1.5 mm hex screwdriver.
  2. Anbernic RG 40XXV Shoulder Button Replacement: passo 2, immagine 1 di 2 Anbernic RG 40XXV Shoulder Button Replacement: passo 2, immagine 2 di 2
    • Take apart the case by separating the front and back sides using an iFixit opening tool.
    • When using the opening tool, carefully pry open the case to avoid damaging the device.
  3. Anbernic RG 40XXV Shoulder Button Replacement: passo 3, immagine 1 di 2 Anbernic RG 40XXV Shoulder Button Replacement: passo 3, immagine 2 di 2
    • Disconnect the battery connection cable by gently pulling it away with angled tweezers from the slot that connects the cable to the motherboard.
    • The cable connection to the motherboard is labeled "+BAT-" for easy identification.
  4. Anbernic RG 40XXV Shoulder Button Replacement, Shoulder Button: passo 4, immagine 1 di 3 Anbernic RG 40XXV Shoulder Button Replacement, Shoulder Button: passo 4, immagine 2 di 3 Anbernic RG 40XXV Shoulder Button Replacement, Shoulder Button: passo 4, immagine 3 di 3
    • Using a Phillips #000 screwdriver, unscrew the six 5 mm screws holding the shoulder buttons in place.
  5. Anbernic RG 40XXV Shoulder Button Replacement: passo 5, immagine 1 di 2 Anbernic RG 40XXV Shoulder Button Replacement: passo 5, immagine 2 di 2
    • Use a pair of ESD-safe tweezers to remove the covers holding the shoulder buttons in place.
    • Place the shoulder button covers to the side to allow easy accessibility to the shoulder buttons for replacement.
  6. Anbernic RG 40XXV Shoulder Button Replacement: passo 6, immagine 1 di 2 Anbernic RG 40XXV Shoulder Button Replacement: passo 6, immagine 2 di 2
    • After removing the covers from the shoulder buttons, pull the buttons out. They will easily dislodge from the back of the case.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 19
Tutti i Tempi: 212
