Salta al contenuto principale
Anbernic RG 40XXV Battery Replacement
Cosa ti serve
  1. Anbernic RG 40XXV Battery Replacement, Back Panel Assembly: passo 1, immagine 1 di 3 Anbernic RG 40XXV Battery Replacement, Back Panel Assembly: passo 1, immagine 2 di 3 Anbernic RG 40XXV Battery Replacement, Back Panel Assembly: passo 1, immagine 3 di 3
    • Remove the micro SD card located on the left and right sides of the device by pushing into the SD card slot and pulling the card out.
    • Unscrew all six 7.5 mm screws on the backside of the case using a 1.5 mm hex screwdriver.
  2. Anbernic RG 40XXV Battery Replacement: passo 2, immagine 1 di 2 Anbernic RG 40XXV Battery Replacement: passo 2, immagine 2 di 2
    • Take apart the case by separating the front and back sides using an iFixit opening tool.
    • When using the opening tool, carefully pry open the case to avoid damaging the device.
  3. Anbernic RG 40XXV Battery Replacement: passo 3, immagine 1 di 2 Anbernic RG 40XXV Battery Replacement: passo 3, immagine 2 di 2
    • Disconnect the battery connection cable by gently pulling it away with angled tweezers from the slot that connects the cable to the motherboard.
    • The cable connection to the motherboard is labeled "+BAT-" for easy identification.
  4. Anbernic RG 40XXV Battery Replacement, Battery: passo 4, immagine 1 di 3 Anbernic RG 40XXV Battery Replacement, Battery: passo 4, immagine 2 di 3 Anbernic RG 40XXV Battery Replacement, Battery: passo 4, immagine 3 di 3
    • Slide a nylon spudger under the battery.
    • Gently pry the battery from the case, releasing the glue holding it in place.
    • If the battery will not come loose, applying force with the nylon spudger at different points of entry may help to free it. Using a hair dryer or heat gun may be helpful to further loosen the glue.
    • When dislodging the battery, be careful not to puncture the battery or battery wrapping to avoid further damaging the device or harming yourself.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device.
  5. Anbernic RG 40XXV Battery Replacement: passo 5, immagine 1 di 1
    • Lift the battery to remove.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 101
Tutti i Tempi: 599
