Salta al contenuto principale
Anbernic RG 40XXV Back Panel Assembly Replacement
Cosa ti serve
  1. Anbernic RG 40XXV Back Panel Assembly Replacement, Back Panel Assembly: passo 1, immagine 1 di 3 Anbernic RG 40XXV Back Panel Assembly Replacement, Back Panel Assembly: passo 1, immagine 2 di 3 Anbernic RG 40XXV Back Panel Assembly Replacement, Back Panel Assembly: passo 1, immagine 3 di 3
    • Remove the micro SD card located on the left and right sides of the device by pushing into the SD card slot and pulling the card out.
    • Unscrew all six 7.5 mm screws on the backside of the case using a 1.5 mm hex screwdriver.
  2. Anbernic RG 40XXV Back Panel Assembly Replacement: passo 2, immagine 1 di 2 Anbernic RG 40XXV Back Panel Assembly Replacement: passo 2, immagine 2 di 2
    • Take apart the case by separating the front and back sides using an iFixit opening tool.
    • When using the opening tool, carefully pry open the case to avoid damaging the device.
  3. Anbernic RG 40XXV Back Panel Assembly Replacement: passo 3, immagine 1 di 2 Anbernic RG 40XXV Back Panel Assembly Replacement: passo 3, immagine 2 di 2
    • Disconnect the battery connection cable by gently pulling it away with angled tweezers from the slot that connects the cable to the motherboard.
    • The cable connection to the motherboard is labeled "+BAT-" for easy identification.
Conclusione
Kristen Gismondi
Membro da: 11/12/14
99.303 Reputazione
255 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 28
Tutti i Tempi: 150
