Salta al contenuto principale
American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement
Cosa ti serve
  1. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement, Remove the sandpaper disc: passo 1, immagine 1 di 1
    • Before you begin, be sure that the sander is unplugged and powered off.
    • Carefully tilt the sander back and lay it down on its side, exposing the three sanding pads on the bottom.
  2. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: passo 2, immagine 1 di 1
    • Peel the hook-and-loop sandpaper disc off of the driver assembly.
  3. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement, Remove the driver pad: passo 3, immagine 1 di 2 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement, Remove the driver pad: passo 3, immagine 2 di 2
    • Use a 3 mm hex key or driver bit to remove the six 11.9 mm-long screws securing the driver pad.
    • Remove the driver pad from the sanding disc.
  4. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement, Remove the sanding disc: passo 4, immagine 1 di 3 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement, Remove the sanding disc: passo 4, immagine 2 di 3 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement, Remove the sanding disc: passo 4, immagine 3 di 3
    • Use a flathead screwdriver to pry off and remove the rubber plug in the center of the sanding disc.
  5. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: passo 5, immagine 1 di 2 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: passo 5, immagine 2 di 2
    • Slide a thin 22 mm wrench underneath the sanding disc and clasp it onto the flat part of the motor driveshaft to keep the driveshaft from turning.
  6. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: passo 6, immagine 1 di 2 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: passo 6, immagine 2 di 2
    • Use an 11 mm socket and socket wrench to remove the 16.5 mm-long bolt securing the sanding disc to the motor driveshaft.
    • Apply counter torque to the driveshaft wrench as you loosen the bolt to keep the sanding disc from spinning.
  7. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: passo 7, immagine 1 di 3 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: passo 7, immagine 2 di 3 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: passo 7, immagine 3 di 3
    • Take two pry bars and insert them underneath the sanding disc as close to the driveshaft as possible.
    • Apply pressure to the pry bars in opposite directions to carefully pry the sanding disc off of the driveshaft.
    • Remove the sanding disc from the floor sander.
  8. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement, Remove the bottom weight and cover: passo 8, immagine 1 di 1
    • Repeat the previous seven steps to remove the other two sanding discs before continuing.
    • With all three sanding discs removed, use a 4 mm hex key to remove four 25.4 mm-long screws securing the bottom cover and bottom weight.
  9. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: passo 9, immagine 1 di 1
    • Lift the bottom weight away from the sander.
  10. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: passo 10, immagine 1 di 3 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: passo 10, immagine 2 di 3 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: passo 10, immagine 3 di 3
    • Pull the top edge of the bottom cover away from the sander until you have enough space to slide the cover out.
    • Slide the cover across the bottom of the sander, away from the wheels, and remove it.
  11. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement, Remove the dust fan: passo 11, immagine 1 di 1
    • Remove the washer from the motor shaft.
  12. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: passo 12, immagine 1 di 3 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: passo 12, immagine 2 di 3 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: passo 12, immagine 3 di 3
    • Pull the drive pad bearing straight off of the motor shaft.
    • You may not be able to remove the bearing with your hands. If this is the case, use a bearing puller to remove the bearing.
  13. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: passo 13, immagine 1 di 3 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: passo 13, immagine 2 di 3 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: passo 13, immagine 3 di 3
    • Using snap ring pliers, pry the snap ring open and slide it off of the motor shaft.
    • Remove the snap ring.
  14. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: passo 14, immagine 1 di 2 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: passo 14, immagine 2 di 2
    • Slide the dust fan straight off of the motor shaft.
Conclusione
Altre 2 persone hanno completato questa guida.
Adam O'Camb
Membro da: 04/11/15
197.108 Reputazione
416 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 447
