Introduzione
This is a guide for disassembling/repairing your American Era Cup Cake Maker.
For disassembly, you will need:
- One 4 inch phillips head screwdriver
- One 3 inch phillips head screwdriver
- One 2.0 mm tri-point screwdriver (or a 2.0 mm flathead screwdriver if you don't have a tri-point tip).
- Organizer for screws (optional)
Cosa ti serve
Open the cup cake maker
Unscrew the 4 Phillips screws attached along the edge of the iron plate.
There are two screws holding a second cardboard plate in place. Unscrew those with the 4 inch screwdriver.
If at this point, the problem is with the feet of the machine, locate the inside of the bottom cover and remove the three screws holding the feet in place with a Phillips screwdriver.
