Identify the connection between the Thermo-Hygrometer sesnor and the body of the array.
The 1st Generation of array does NOT have a removable sensor. It is covered in a white glue.
The 2nd and 3rd Generation DO have removable sensor chips. You will see a small black ring, which is the bottom of the sensor mount.
Identify which Generation of Chip the array has.
The 1st Generation is NOT removable, and the entire array will need to be replaced.
The 2nd Generation IS removable, however, the chip is not replaceable. The entire array will need to be replaced.
The 3rd Generation IS removable, and replaceable. A new chip should get the unit up and running again.
Incorpora questa guida
Scegli una dimensione e copia il codice qui sotto per incorporare questa guida come un piccolo widget sul tuo sito/forum.
Anteprima
