Salta al contenuto principale
AmazonBasics BTV1 Speaker Replacement
Cosa ti serve
  1. AmazonBasics BTV1 Speaker Replacement, Speaker: passo 1, immagine 1 di 2 AmazonBasics BTV1 Speaker Replacement, Speaker: passo 1, immagine 2 di 2
    • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
    • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
  2. AmazonBasics BTV1 Speaker Replacement: passo 2, immagine 1 di 2 AmazonBasics BTV1 Speaker Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
    • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
  3. AmazonBasics BTV1 Speaker Replacement: passo 3, immagine 1 di 2 AmazonBasics BTV1 Speaker Replacement: passo 3, immagine 2 di 2
    • Tilt the case downwards until the speakers fall out of their housings.
    • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
  4. AmazonBasics BTV1 Speaker Replacement: passo 4, immagine 1 di 2 AmazonBasics BTV1 Speaker Replacement: passo 4, immagine 2 di 2
    • Gently pull the two plastic connectors from the motherboard.
    • Lift the front panel of the case and remove the speakers.
Conclusione
Altre 2 persone hanno completato questa guida.
Chris Shannon
Membro da: 02/01/16
1.039 Reputazione
5 Guide realizzate
USF Tampa, Team 14-2, Lacy Spring 2016 Membro di USF Tampa, Team 14-2, Lacy Spring 2016
USFT-LACY-S16S14G2
3 Membri
5 Guide realizzate
Un commento
Where do you get replacement speakers? What kind?
laurieshorter - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,955
