Salta al contenuto principale
AmazonBasics BTV1 Motherboard Replacement
Cosa ti serve
  1. AmazonBasics BTV1 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 AmazonBasics BTV1 Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
    • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
  2. AmazonBasics BTV1 Motherboard Replacement: passo 2, immagine 1 di 2 AmazonBasics BTV1 Motherboard Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
    • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
  3. AmazonBasics BTV1 Motherboard Replacement: passo 3, immagine 1 di 2 AmazonBasics BTV1 Motherboard Replacement: passo 3, immagine 2 di 2
    • Tilt the case downwards until the speakers fall out of their housings.
    • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
  4. AmazonBasics BTV1 Motherboard Replacement: passo 4, immagine 1 di 2 AmazonBasics BTV1 Motherboard Replacement: passo 4, immagine 2 di 2
    • Gently pull each plastic connector from the motherboard.
    • Take a note of which connector goes with each component for easy reassembly.
    • Use a Phillips #1 screwdriver to remove each of the three black 9.6mm screws from the motherboard.
  5. AmazonBasics BTV1 Motherboard Replacement: passo 5, immagine 1 di 1
    • Gently pull out the two ribbon connectors to disconnect the motherboard from the case.
Conclusione
Altre 2 persone hanno completato questa guida.
Chris Shannon
Membro da: 02/01/16
1.039 Reputazione
5 Guide realizzate
USF Tampa, Team 14-2, Lacy Spring 2016 Membro di USF Tampa, Team 14-2, Lacy Spring 2016
USFT-LACY-S16S14G2
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 481
