Salta al contenuto principale
AmazonBasics B00Q3KFX8U Power Cable Replacement
Cosa ti serve
  1. AmazonBasics B00Q3KFX8U Power Cable Replacement, Drive Gear: passo 1, immagine 1 di 1
    • Remove the shredder assembly from the paper scrap bin.
  2. AmazonBasics B00Q3KFX8U Power Cable Replacement: passo 2, immagine 1 di 1
    • Remove the two 10mm PH1 screws holding the small black panel in place.
  3. AmazonBasics B00Q3KFX8U Power Cable Replacement: passo 3, immagine 1 di 2 AmazonBasics B00Q3KFX8U Power Cable Replacement: passo 3, immagine 2 di 2
    • Remove the six 14mm PH1 screws holding the bottom cover in place.
    • Remove the cover by lifting straight upwards.
    • One of the screws will be hidden beneath a warranty sticker. Simply push the head of the screwdriver through the sticker to access the screw.
  4. AmazonBasics B00Q3KFX8U Power Cable Replacement: passo 4, immagine 1 di 1
    • Remove the blade/motor assembly from the top cover by lifting straight upwards. Do not disconnect any wiring just yet.
    • The blades are sharp. Coming into contact with them may result in injury.
  5. AmazonBasics B00Q3KFX8U Power Cable Replacement: passo 5, immagine 1 di 2 AmazonBasics B00Q3KFX8U Power Cable Replacement: passo 5, immagine 2 di 2
    • Remove the five 8mm PH2 screws from the bracket holding the gears in place.
  6. AmazonBasics B00Q3KFX8U Power Cable Replacement: passo 6, immagine 1 di 1
    • Use a metal spudger to pry the bracket from the main shredder assembly.
    • If the bracket is attached too tightly for the spudger, carefully use a metal screwdriver to pry it loose.
  7. AmazonBasics B00Q3KFX8U Power Cable Replacement: passo 7, immagine 1 di 2 AmazonBasics B00Q3KFX8U Power Cable Replacement: passo 7, immagine 2 di 2
    • Remove the two plastic drive gears from the shredder assembly by lifting straight upwards.
  8. AmazonBasics B00Q3KFX8U Power Cable Replacement, Motor: passo 8, immagine 1 di 1
    • Remove the four 18mm PH2 screws holding the motor to the main shredder assembly.
  9. AmazonBasics B00Q3KFX8U Power Cable Replacement: passo 9, immagine 1 di 1
    • Disconnect the motor from the motherboard by either clipping the wires, or using a soldering iron to disconnect the wires directly at the board.
    • To reattach the motor, solder the wires back together, or to the motherboard depending on how you removed them.
  10. AmazonBasics B00Q3KFX8U Power Cable Replacement, Power Cable: passo 10, immagine 1 di 1
    • Remove the two 8mm PH1 screws holding the IR sensor wire in place. This will give you more room to work with later on.
  11. AmazonBasics B00Q3KFX8U Power Cable Replacement: passo 11, immagine 1 di 2 AmazonBasics B00Q3KFX8U Power Cable Replacement: passo 11, immagine 2 di 2
    • Remove the two 10mm PH1 screws holding the motherboard in place.
    • Remove the motherboard by lifting straight upwards from the top cover.
  12. AmazonBasics B00Q3KFX8U Power Cable Replacement: passo 12, immagine 1 di 1
    • To disconnect the power wire, remove the black and white wires on the far edges of the motherboard.
    • To reassemble, solder the wires back to the motherboard in the same location as they previously were.
    • When reassembling, be sure to replace the wires in the correct locations. Reversing the wires will short circuit the motherboard and may damage the device or injure yourself.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 599
