Salta al contenuto principale
AmazonBasics B00Q3KFX8U Drive Gear Replacement
Cosa ti serve
  1. AmazonBasics B00Q3KFX8U Drive Gear Replacement, Drive Gear: passo 1, immagine 1 di 1
    • Remove the shredder assembly from the paper scrap bin.
  2. AmazonBasics B00Q3KFX8U Drive Gear Replacement: passo 2, immagine 1 di 1
    • Remove the two 10mm PH1 screws holding the small black panel in place.
  3. AmazonBasics B00Q3KFX8U Drive Gear Replacement: passo 3, immagine 1 di 2 AmazonBasics B00Q3KFX8U Drive Gear Replacement: passo 3, immagine 2 di 2
    • Remove the six 14mm PH1 screws holding the bottom cover in place.
    • Remove the cover by lifting straight upwards.
    • One of the screws will be hidden beneath a warranty sticker. Simply push the head of the screwdriver through the sticker to access the screw.
  4. AmazonBasics B00Q3KFX8U Drive Gear Replacement: passo 4, immagine 1 di 1
    • Remove the blade/motor assembly from the top cover by lifting straight upwards. Do not disconnect any wiring just yet.
    • The blades are sharp. Coming into contact with them may result in injury.
  5. AmazonBasics B00Q3KFX8U Drive Gear Replacement: passo 5, immagine 1 di 2 AmazonBasics B00Q3KFX8U Drive Gear Replacement: passo 5, immagine 2 di 2
    • Remove the five 8mm PH2 screws from the bracket holding the gears in place.
  6. AmazonBasics B00Q3KFX8U Drive Gear Replacement: passo 6, immagine 1 di 1
    • Use a metal spudger to pry the bracket from the main shredder assembly.
    • If the bracket is attached too tightly for the spudger, carefully use a metal screwdriver to pry it loose.
  7. AmazonBasics B00Q3KFX8U Drive Gear Replacement: passo 7, immagine 1 di 2 AmazonBasics B00Q3KFX8U Drive Gear Replacement: passo 7, immagine 2 di 2
    • Remove the two plastic drive gears from the shredder assembly by lifting straight upwards.
Conclusione
2 Commenti
Where does one buy these gear parts?
opticdreams - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 32
Tutti i Tempi: 1,310
