Salta al contenuto principale
Amazon Luna Controller Buttons Replacement
Cosa ti serve
  1. Amazon Luna Controller Buttons Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the controller over so that the back panel is facing up.
  2. Amazon Luna Controller Buttons Replacement: passo 2, immagine 1 di 3 Amazon Luna Controller Buttons Replacement: passo 2, immagine 2 di 3 Amazon Luna Controller Buttons Replacement: passo 2, immagine 3 di 3
    • Locate the latch on the back panel.
    • Pull down gently to open the compartment and expose the battery slots.
    • Remove batteries.
  3. Amazon Luna Controller Buttons Replacement, Faceplate: passo 3, immagine 1 di 1
    • Flip the controller over to its front and locate the seam where the front plate connects to the rest of the body.
  4. Amazon Luna Controller Buttons Replacement: passo 4, immagine 1 di 1
    • Hold the controller firmly.
    • Insert the thin edge of an iFixit opening tool into the seam at the edge of the front plate close to the A button.
    • Work slowly and carefully around all sides to avoid snapping the clips.
  5. Amazon Luna Controller Buttons Replacement: passo 5, immagine 1 di 2 Amazon Luna Controller Buttons Replacement: passo 5, immagine 2 di 2
    • Once all clips are released, lift the front plate away from the controller.
  6. Amazon Luna Controller Buttons Replacement, Buttons: passo 6, immagine 1 di 2 Amazon Luna Controller Buttons Replacement, Buttons: passo 6, immagine 2 di 2
    • Remove the six 8 mm screws securing the controller's body using a TR9 Torx screwdriver.
  7. Amazon Luna Controller Buttons Replacement: passo 7, immagine 1 di 2 Amazon Luna Controller Buttons Replacement: passo 7, immagine 2 di 2
    • Gently pry along the seam that separates the two halves of the controller using an opening tool.
    • Work your way around the perimeter to carefully release the clips securing the two halves.
  8. Amazon Luna Controller Buttons Replacement: passo 8, immagine 1 di 3 Amazon Luna Controller Buttons Replacement: passo 8, immagine 2 di 3 Amazon Luna Controller Buttons Replacement: passo 8, immagine 3 di 3
    • Lay the front of the controller shell downward.
    • Remove the rubber padding that keeps the buttons in place.
    • Remove the buttons from the shell housing.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 152
