Salta al contenuto principale
Amazon FireTV Stick Motherboard Replacement
Cosa ti serve
  1. Amazon FireTV Stick Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 Amazon FireTV Stick Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Insert a plastic opening tool into the seam on either side of the device.
    • Side the plastic opening tools along the seam of the stick and pry the top half of the case away from the bottom.
    • Don't force the case apart. If you've successfully unhooked all of the clips, the case will be easy to remove.
  2. Amazon FireTV Stick Motherboard Replacement: passo 2, immagine 1 di 2 Amazon FireTV Stick Motherboard Replacement: passo 2, immagine 2 di 2
    • Lift the back of the motherboard and slide it out of the case.
Conclusione
Altre 23 persone hanno completato questa guida.
Sami Uzzama
Membro da: 07/12/16
516 Reputazione
2 Guide realizzate
IUPUI, Team 2-3, Harley SU 2016 Membro di IUPUI, Team 2-3, Harley SU 2016
IUPUI-HARLEY-SU16S2G3
4 Membri
12 Guide realizzate
10 Commenti
Where can you purchase a new motherboard for the TV stick?
Brandon Boykin - Replica
Where can you get a new mobo? Mine was defective from day one. Amazon thought it was the remote and replaced the remote. It still didn't work. When I contacted them to state this and get a new stick, they informed me they had refunded my purchase and I would just need to buy a new stick.They said I can through this one away. This was frustrating and being the tinkerer I am I want to get this thing to work now. If there is any info on any connections that I can reinforce that would be great too.
blindzen - Replica
My firestick has no sound and a little headphone icon pops up in the corner of my tv screen…how can i fix it??please heeeellllppp!!
Rzackery - Replica
Your TV sound is off, I think.
[deleted] -
Some issues are caused by the flexing of the Stick (being inserted & removed) around the HDMI connector internally, in addition to the Heat dissipation issues the Fire TV Stick is known for having……. I have just re-soldered the internal cracks around the HDMI connector on my Fire TV Stick & have replaced the Amazon provided USB power adaptor (which is 1.0 ampere) with another adaptor that I have (Which is 1.35 ampere) & the stick is now operating as well if not better than it ever has
Leigh Towers - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 64
Ultimi 30 Giorni: 307
Tutti i Tempi: 32,475
