Salta al contenuto principale
Amazon Fire TV Cube Motherboard Replacement
Cosa ti serve
  1. Amazon Fire TV Cube Motherboard Replacement, Speaker: passo 1, immagine 1 di 3 Amazon Fire TV Cube Motherboard Replacement, Speaker: passo 1, immagine 2 di 3 Amazon Fire TV Cube Motherboard Replacement, Speaker: passo 1, immagine 3 di 3
    • Using a metal spudger, push down between the edge seals on the base and pry off the base.
    • Do not confuse the top thin layer of rubber with the thick palette that needs to be removed.
    • This may require substantial force.
  2. Amazon Fire TV Cube Motherboard Replacement: passo 2, immagine 1 di 3 Amazon Fire TV Cube Motherboard Replacement: passo 2, immagine 2 di 3 Amazon Fire TV Cube Motherboard Replacement: passo 2, immagine 3 di 3
    • Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer.
    • There are 4 washers to go with each of the screws.
  3. Amazon Fire TV Cube Motherboard Replacement: passo 3, immagine 1 di 1
    • Lift and remove the full frame.
  4. Amazon Fire TV Cube Motherboard Replacement: passo 4, immagine 1 di 2 Amazon Fire TV Cube Motherboard Replacement: passo 4, immagine 2 di 2
    • Lift and remove the speaker.
    • Carefully match the outlets on the speaker with the outlets on the motherboard.
  5. Amazon Fire TV Cube Motherboard Replacement, Motherboard: passo 5, immagine 1 di 2 Amazon Fire TV Cube Motherboard Replacement, Motherboard: passo 5, immagine 2 di 2
    • Lift the black latch by gently prying up with the flat end of the Spudger.
    • Detach the copper tap by pulling it out.
  6. Amazon Fire TV Cube Motherboard Replacement: passo 6, immagine 1 di 2 Amazon Fire TV Cube Motherboard Replacement: passo 6, immagine 2 di 2
    • Use the pointed end of the Spudger to carefully detach the black and white wires from the motherboard.
    • Make sure all three attachments (the copper tab and both wires) are fully disconnected before continuing.
  7. Amazon Fire TV Cube Motherboard Replacement: passo 7, immagine 1 di 2 Amazon Fire TV Cube Motherboard Replacement: passo 7, immagine 2 di 2
    • Gently pry the motherboard up and off.
    Nobody anywhere has these motherboards so what good are instructions to replace. It’s like being given a car that doesn’t have keys and those keys can’t be made anywhere.
    futuregu - Replica
Conclusione
Altre 3 persone hanno completato questa guida.
2 Commenti
where do you buy the mother board ?
Sam Handa - Replica
This would be perfect if I could buy the dam motherboard. Where does one get because so far I’m not finding crap.
futuregu - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 57
Tutti i Tempi: 1,888
