Salta al contenuto principale
Amazon Fire Phone Headphone Jack Replacement
Cosa ti serve
  1. Amazon Fire Phone Headphone Jack Replacement, Front Panel Assembly: passo 1, immagine 1 di 1
    • If the display is damaged use clear packing tape to contain any glass shards.
    • Make sure the entire surface of the display is covered with tape.
    • Wear safety glasses to protect your eyes.
  2. Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: passo 2, immagine 1 di 3 Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: passo 2, immagine 2 di 3 Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: passo 2, immagine 3 di 3
    • Power off your phone.
    • Remove the sim card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
    • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
  3. Amazon Fire Phone Headphone Jack Replacement, Manual Opening: passo 3, immagine 1 di 3 Amazon Fire Phone Headphone Jack Replacement, Manual Opening: passo 3, immagine 2 di 3 Amazon Fire Phone Headphone Jack Replacement, Manual Opening: passo 3, immagine 3 di 3
    • Press the single suction cup just above the home button.
    • While lifting up on the suction cup place the plastic opening tool at the rim of the screen, separating the screen from the back casing.
    • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
    • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone, freeing the two halves.
  4. Amazon Fire Phone Headphone Jack Replacement: passo 4, immagine 1 di 3 Amazon Fire Phone Headphone Jack Replacement: passo 4, immagine 2 di 3 Amazon Fire Phone Headphone Jack Replacement: passo 4, immagine 3 di 3
    • Remove the 1mm screw concealed in the headphone jack.
    • Afterwards the headphone jack will easily pop off.
Conclusione
Altre 2 persone hanno completato questa guida.
Savannah Moen
Membro da: 10/29/15
234 Reputazione
1 Guida realizzata
Cal Poly, Team 5-7, Maness Fall 2015 Membro di Cal Poly, Team 5-7, Maness Fall 2015
CPSU-MANESS-F15S5G7
5 Membri
10 Guide realizzate
Un commento
hello sir i need amazon fire back casing in Pakistan
Kashif Arif - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,824
