Introduzione
Remove the display screen in order to fix a broken screen.
Cosa ti serve
Power off your phone.
Remove the SIM card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
Press the small suction cup just above the home button.
While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
Using the J000 screwdriver head, remove the three 3mm screws holding the bracket in place.
Remove the silver bracket that was held into place by the three screws just removed.
Disconnect the battery connection cable by using the plastic opening tool and applying light pressure upwards on the cable.
Unscrew the 1mm screw on the top left side of the phone
Maneuver the bracket off slowly
Place the iOpener in the center of the microwave.
Heat the iOpener for thirty seconds.
Altre 4 persone hanno completato questa guida.
