Salta al contenuto principale
Amazon Fire HD 8 Rear-facing Camera Replacement
Cosa ti serve
  1. Amazon Fire HD 8 Rear-facing Camera Replacement, Screen: passo 1, immagine 1 di 2 Amazon Fire HD 8 Rear-facing Camera Replacement, Screen: passo 1, immagine 2 di 2
    • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
    • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
  2. Amazon Fire HD 8 Rear-facing Camera Replacement: passo 2, immagine 1 di 1
    • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
    • Be careful not to bend the screen by pushing it too far from the rest of the device.
  3. Amazon Fire HD 8 Rear-facing Camera Replacement: passo 3, immagine 1 di 3 Amazon Fire HD 8 Rear-facing Camera Replacement: passo 3, immagine 2 di 3 Amazon Fire HD 8 Rear-facing Camera Replacement: passo 3, immagine 3 di 3
    • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
    • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
  4. Amazon Fire HD 8 Rear-facing Camera Replacement: passo 4, immagine 1 di 3 Amazon Fire HD 8 Rear-facing Camera Replacement: passo 4, immagine 2 di 3 Amazon Fire HD 8 Rear-facing Camera Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
  5. Amazon Fire HD 8 Rear-facing Camera Replacement, Rear-facing Camera: passo 5, immagine 1 di 2 Amazon Fire HD 8 Rear-facing Camera Replacement, Rear-facing Camera: passo 5, immagine 2 di 2
    Compra
    • Pop the camera out of the rear-facing camera casing by carefully pulling the orange cable with the tweezers.
  6. Amazon Fire HD 8 Rear-facing Camera Replacement: passo 6, immagine 1 di 2 Amazon Fire HD 8 Rear-facing Camera Replacement: passo 6, immagine 2 di 2
    • Flip up the tab on the ZIF connector at the end of the ribbon cable.
    • Grasp the underside of the orange cable with the tweezers and gently slide the camera out of the connector.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 1-3, Leahy Spring 2016 Membro di USF Tampa, Team 1-3, Leahy Spring 2016
USFT-LEAHY-S16S1G3
4 Membri
17 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 2,021
