Salta al contenuto principale
Amazon Fire HD 8 Bottom Speaker Replacement
Cosa ti serve
  1. Amazon Fire HD 8 Bottom Speaker Replacement, Screen: passo 1, immagine 1 di 2 Amazon Fire HD 8 Bottom Speaker Replacement, Screen: passo 1, immagine 2 di 2
    • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
    • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
  2. Amazon Fire HD 8 Bottom Speaker Replacement: passo 2, immagine 1 di 1
    • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
    • Be careful not to bend the screen by pushing it too far from the rest of the device.
  3. Amazon Fire HD 8 Bottom Speaker Replacement: passo 3, immagine 1 di 3 Amazon Fire HD 8 Bottom Speaker Replacement: passo 3, immagine 2 di 3 Amazon Fire HD 8 Bottom Speaker Replacement: passo 3, immagine 3 di 3
    • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
    • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
  4. Amazon Fire HD 8 Bottom Speaker Replacement: passo 4, immagine 1 di 3 Amazon Fire HD 8 Bottom Speaker Replacement: passo 4, immagine 2 di 3 Amazon Fire HD 8 Bottom Speaker Replacement: passo 4, immagine 3 di 3
    • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
  5. Amazon Fire HD 8 Bottom Speaker Replacement, Bottom Speaker: passo 5, immagine 1 di 1
    • Using tweezers, carefully lift the copper strip from the right side of the speaker.
  6. Amazon Fire HD 8 Bottom Speaker Replacement: passo 6, immagine 1 di 2 Amazon Fire HD 8 Bottom Speaker Replacement: passo 6, immagine 2 di 2
    • Remove the two screws located on the top left and bottom right of the speaker using a T4 screwdriver.
  7. Amazon Fire HD 8 Bottom Speaker Replacement: passo 7, immagine 1 di 1
    • Lift the right side of the speaker and carefully unhook and remove it from the device.
    • Be mindful of the white wire connecting the speaker to the device.
  8. Amazon Fire HD 8 Bottom Speaker Replacement: passo 8, immagine 1 di 2 Amazon Fire HD 8 Bottom Speaker Replacement: passo 8, immagine 2 di 2
    • Set aside the black speaker and follow the white wire to its connection on the upper left side of the motherboard.
    • Using tweezers, gently pry the black clip upward from the board.
Conclusione
USF Tampa, Team 1-3, Leahy Spring 2016 Membro di USF Tampa, Team 1-3, Leahy Spring 2016
USFT-LEAHY-S16S1G3
4 Membri
17 Guide realizzate
Un commento
I would like to ask if you happen to know the part number of the speaker and where I could acquire said device?
Thank you a very helpful walk-through guide
Keven Paxton - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 21
Tutti i Tempi: 4,132
