Introduzione
In this guide, we outline how to properly disassemble this device and replace the LCD display screen.
Cosa ti serve
Insert the plastic opening tool behind the rear case to free the clips holding the case together.
Work your way around the device to free all the clips.
Carefully unplug the three wire connections by placing a plastic spudger under the connections and lifting up.
Disconnect the battery and speaker connections by placing the round handle spudger under the wires and lifting up and out.
Disconnect the display connections from the motherboard by using the plastic spudger to lift the clamp holding the ribbon cable. Then, using the tweezers, grab the ribbon wire and pull away from the motherboard.
Following the bottom edge of the device, remove the (3) T5 hex silver screws with the T5 torx screwdriver.
Altre 7 persone hanno completato questa guida.
