Salta al contenuto principale
Amazon Fire HD 7 (4th Generation) Rear facing camera replacement
Cosa ti serve
  1. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: passo 1, immagine 1 di 3 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: passo 1, immagine 2 di 3 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: passo 1, immagine 3 di 3
    • Insert the plastic opening tool behind the rear case to free the clips holding the case together.
    • Work your way around the device to free all the clips.
  2. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: passo 2, immagine 1 di 1
    • There are an additional nine clips surrounding the battery area. Place the plastic tool into the clips and lift to disconnect them.
    • Once all clips have been released, the back case can be pulled free to reveal the inside of the device.
  3. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: passo 3, immagine 1 di 1
    • Use a nylon spudger to unclip the connection from the motherboard.
  4. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: passo 4, immagine 1 di 2 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: passo 4, immagine 2 di 2
    • Unscrew the two screws using a T5 screwdriver.
    • The camera lens are sensitive. Be careful when removing and handling camera.
    • Once freed from the screws, gently lift and remove the camera.
Conclusione
Omir Rosado
Membro da: 09/30/16
725 Reputazione
5 Guide realizzate
USF Tampa, Team 4-4, Passmore Fall 2016 Membro di USF Tampa, Team 4-4, Passmore Fall 2016
USFT-PASSMORE-F16S4G4
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 586
