Salta al contenuto principale
Amazon Fire HD 3rd Gen Disassembly
Cosa ti serve
  1. Amazon Fire HD 3rd Gen Disassembly, Pry off the plastic back.: passo 1, immagine 1 di 3 Amazon Fire HD 3rd Gen Disassembly, Pry off the plastic back.: passo 1, immagine 2 di 3 Amazon Fire HD 3rd Gen Disassembly, Pry off the plastic back.: passo 1, immagine 3 di 3
    • Using a Jimmy, start at the volume control and work your way around by prying off the back and then lifting it back like a book.
  2. Amazon Fire HD 3rd Gen Disassembly, Peeling off the tape.: passo 2, immagine 1 di 3 Amazon Fire HD 3rd Gen Disassembly, Peeling off the tape.: passo 2, immagine 2 di 3 Amazon Fire HD 3rd Gen Disassembly, Peeling off the tape.: passo 2, immagine 3 di 3
    • Peel off the 2 yellow pieces of yellow tape on the battery.
  3. Amazon Fire HD 3rd Gen Disassembly, Disconnect the ribbon cables: passo 3, immagine 1 di 3 Amazon Fire HD 3rd Gen Disassembly, Disconnect the ribbon cables: passo 3, immagine 2 di 3 Amazon Fire HD 3rd Gen Disassembly, Disconnect the ribbon cables: passo 3, immagine 3 di 3
    • Take off all the ribbon cables connected to the main board. (Marked in Red)
    • On the 2 speakers marked in yellow, be sure to pull straight up. Then unclip the speaker cables.
  4. Amazon Fire HD 3rd Gen Disassembly, Unscrew speakers and gray bracket: passo 4, immagine 1 di 1
    • Using a T4 Torx driver, unscrew each of the 2 screws holding in the 2 speakers. (red)
    • Then, take out the 7 screws hold in the gray bracket (yellow)
    • Now, unscrew the 8 screws holding the motherboard. (green)
  5. Amazon Fire HD 3rd Gen Disassembly, Unscrew the I/O: passo 5, immagine 1 di 1
    • Next, use a T4 Torx Screwdriver again to unscrew the headphone jack and the Micro USB port.
  6. Amazon Fire HD 3rd Gen Disassembly, Take everything out.: passo 6, immagine 1 di 1
    • 1. Remove the Headphone and USB ports.
    • 2. Remove motherboard.
    • 3. Remove the speakers.
    • 4. Remove gray bracket with battery.
  7. Amazon Fire HD 3rd Gen Disassembly, Remove the screen.: passo 7, immagine 1 di 1
    • Now, using a T4, unscrew the 4 screws holding in the screen.
  8. Amazon Fire HD 3rd Gen Disassembly, Your Done!: passo 8, immagine 1 di 1
    • Congrats! Now follow the directions in reverse to reassemble your Fire!
Linea Traguardo
Altre 3 persone hanno completato questa guida.
1Commento della guida
Please where can I get the digitizer?
Mine is shattered and I haven't used it for over 3years but I can still power it up.
Will very much appreciate a lead.
Patrick,
Nigeria
Patrick Mordi - Replica Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 42
Tutti i Tempi: 2,092
