Salta al contenuto principale
Amazon Fire HD 10 Rear Facing Camera Replacement
Cosa ti serve
  1. Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: passo 1, immagine 1 di 3 Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: passo 1, immagine 2 di 3 Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: passo 1, immagine 3 di 3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Amazon Fire HD 10 Rear Facing Camera Replacement: passo 2, immagine 1 di 1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Amazon Fire HD 10 Rear Facing Camera Replacement: passo 3, immagine 1 di 2 Amazon Fire HD 10 Rear Facing Camera Replacement: passo 3, immagine 2 di 2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Rear Facing Camera Replacement: passo 4, immagine 1 di 1
    • Remove the screen and digitizer from the case completely.
  5. Amazon Fire HD 10 Rear Facing Camera Replacement, Rear Facing Camera: passo 5, immagine 1 di 2 Amazon Fire HD 10 Rear Facing Camera Replacement, Rear Facing Camera: passo 5, immagine 2 di 2
    • Remove the single T5 Torx screw at the base of the camera.
    • Once removed, place the screw aside in a safe location.
  6. Amazon Fire HD 10 Rear Facing Camera Replacement: passo 6, immagine 1 di 2 Amazon Fire HD 10 Rear Facing Camera Replacement: passo 6, immagine 2 di 2
    • Lift the camera from the case using the plastic opening tool.
    • The camera is still connected to the motherboard via the ZIF connector.
  7. Amazon Fire HD 10 Rear Facing Camera Replacement: passo 7, immagine 1 di 2 Amazon Fire HD 10 Rear Facing Camera Replacement: passo 7, immagine 2 di 2
    • Gently grab the camera and pull to remove.
    • The camera is now free from the motherboard.
Conclusione
Altre 2 persone hanno completato questa guida.
Jaie Hillery
Membro da: 10/07/14
1.718 Reputazione
10 Guide realizzate
USF Tampa, Team 16-6, Blackwell Winter 2016 Membro di USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 Membri
22 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 873
