Salta al contenuto principale
Amazon Fire HD 10 Motherboard Replacement
Cosa ti serve
  1. Amazon Fire HD 10 Motherboard Replacement, Screen: passo 1, immagine 1 di 3 Amazon Fire HD 10 Motherboard Replacement, Screen: passo 1, immagine 2 di 3 Amazon Fire HD 10 Motherboard Replacement, Screen: passo 1, immagine 3 di 3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Amazon Fire HD 10 Motherboard Replacement: passo 2, immagine 1 di 1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Amazon Fire HD 10 Motherboard Replacement: passo 3, immagine 1 di 2 Amazon Fire HD 10 Motherboard Replacement: passo 3, immagine 2 di 2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove the screen and digitizer from the case completely.
  5. Amazon Fire HD 10 Motherboard Replacement, Battery: passo 5, immagine 1 di 3 Amazon Fire HD 10 Motherboard Replacement, Battery: passo 5, immagine 2 di 3 Amazon Fire HD 10 Motherboard Replacement, Battery: passo 5, immagine 3 di 3
    • Locate the power cable that links the battery to the motherboard.
    • Carefully unplug the battery power cable to disconnect the battery from the motherboard.
    • The third image shows what it should look like with the battery power cable is disconnected.
  6. Amazon Fire HD 10 Motherboard Replacement: passo 6, immagine 1 di 3 Amazon Fire HD 10 Motherboard Replacement: passo 6, immagine 2 di 3 Amazon Fire HD 10 Motherboard Replacement: passo 6, immagine 3 di 3
    • Begin by locating the double sided pull tape locations.
    • Do not lift on the battery when doing the following step. You will bend it. It is very pliable.
    • Pull the black soft tabs to release the tape's adhesion.
    • Make sure you pull the tabs slowly and continuously away from the case until the adhesive is completely out.
    • Do this to all 4 tabs until the battery is completely free of adhesion to the device's backing.
  7. Amazon Fire HD 10 Motherboard Replacement: passo 7, immagine 1 di 3 Amazon Fire HD 10 Motherboard Replacement: passo 7, immagine 2 di 3 Amazon Fire HD 10 Motherboard Replacement: passo 7, immagine 3 di 3
    • Make sure all the adhesive is removed before trying to lift the battery from the case.
    • After the battery is totally free of any adhesion, simply lift the battery from the case.
  8. Amazon Fire HD 10 Motherboard Replacement: passo 8, immagine 1 di 3 Amazon Fire HD 10 Motherboard Replacement: passo 8, immagine 2 di 3 Amazon Fire HD 10 Motherboard Replacement: passo 8, immagine 3 di 3
    • Inspect battery for any leakage.
    • Please follow all U.S. regulations and laws when disposing or recycling the battery.
  9. Amazon Fire HD 10 Motherboard Replacement, Rear Facing Camera: passo 9, immagine 1 di 2 Amazon Fire HD 10 Motherboard Replacement, Rear Facing Camera: passo 9, immagine 2 di 2
    • Remove the single T5 Torx screw at the base of the camera.
    • Once removed, place the screw aside in a safe location.
  10. Amazon Fire HD 10 Motherboard Replacement: passo 10, immagine 1 di 2 Amazon Fire HD 10 Motherboard Replacement: passo 10, immagine 2 di 2
    • Lift the camera from the case using the plastic opening tool.
    • The camera is still connected to the motherboard via the ZIF connector.
  11. Amazon Fire HD 10 Motherboard Replacement: passo 11, immagine 1 di 2 Amazon Fire HD 10 Motherboard Replacement: passo 11, immagine 2 di 2
    • Gently grab the camera and pull to remove.
    • The camera is now free from the motherboard.
  12. Amazon Fire HD 10 Motherboard Replacement, Front Facing Camera: passo 12, immagine 1 di 3 Amazon Fire HD 10 Motherboard Replacement, Front Facing Camera: passo 12, immagine 2 di 3 Amazon Fire HD 10 Motherboard Replacement, Front Facing Camera: passo 12, immagine 3 di 3
    • Remove the two screws from front facing camera using the T5 Torx Screwdriver.
    • Make sure you place the screws in a safe location nearby.
  13. Amazon Fire HD 10 Motherboard Replacement: passo 13, immagine 1 di 2 Amazon Fire HD 10 Motherboard Replacement: passo 13, immagine 2 di 2
    • Lift the black plastic cover once the screws are removed.
    • Place aside for later reassembly.
  14. Amazon Fire HD 10 Motherboard Replacement: passo 14, immagine 1 di 2 Amazon Fire HD 10 Motherboard Replacement: passo 14, immagine 2 di 2
    • Detach the connector using a plastic opening tool or spudger.
    • The camera is still connected to the motherboard.
  15. Amazon Fire HD 10 Motherboard Replacement: passo 15, immagine 1 di 2 Amazon Fire HD 10 Motherboard Replacement: passo 15, immagine 2 di 2
    • Grip the camera and lift up to detach the ZIF connector from the motherboard.
  16. Amazon Fire HD 10 Motherboard Replacement, Motherboard: passo 16, immagine 1 di 1
    • Lift the ZIF connector up to disconnect from the motherboard.
  17. Amazon Fire HD 10 Motherboard Replacement: passo 17, immagine 1 di 3 Amazon Fire HD 10 Motherboard Replacement: passo 17, immagine 2 di 3 Amazon Fire HD 10 Motherboard Replacement: passo 17, immagine 3 di 3
    • Disconnect the connectors using the plastic opening tool.
  18. Amazon Fire HD 10 Motherboard Replacement: passo 18, immagine 1 di 2 Amazon Fire HD 10 Motherboard Replacement: passo 18, immagine 2 di 2
    • Remove the ten T5 Torx screws securing the motherboard to the case.
    • Keep the screws together in a safe place for reassembly.
  19. Amazon Fire HD 10 Motherboard Replacement: passo 19, immagine 1 di 3 Amazon Fire HD 10 Motherboard Replacement: passo 19, immagine 2 di 3 Amazon Fire HD 10 Motherboard Replacement: passo 19, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Lift and pull the motherboard down, gently, towards the case using the tweezers.
Conclusione
Altre 14 persone hanno completato questa guida.
Jaie Hillery
Membro da: 10/07/14
1.718 Reputazione
10 Guide realizzate
USF Tampa, Team 16-6, Blackwell Winter 2016 Membro di USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 Membri
22 Guide realizzate
6 Commenti
Just for the record, my screws were T4, not T5.
scottpickles - Replica
Where is a reliable store to buy this motherboard?
Jimmy Lee - Replica
what you left out is the speakers are they still attached to the motherboard you get 15 points
elliott reitman - Replica
Is this the Kindle? Not the Tablet?
imbritneyedwards - Replica
I have exhausted all online searches for a new HD Fire 10.1 7 generation motherboard replacement and have not been able to locate one anywhere do you have any places you know of that sell these types of motherboards?
Thanks,
Al Silva
Al Silva - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 59
Ultimi 30 Giorni: 268
Tutti i Tempi: 21,668
