Salta al contenuto principale
Amazon Fire Game Controller Motherboard Replacement
Cosa ti serve
  1. Amazon Fire Game Controller Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Use a Triangle #2 screwdriver to remove the six 10 mm screws from the back of the controller.
  2. Amazon Fire Game Controller Motherboard Replacement: passo 2, immagine 1 di 1
    • Pry the two shell pieces from one another from the top orientation with a plastic opening tool.
    • The weights will fall out.
  3. Amazon Fire Game Controller Motherboard Replacement: passo 3, immagine 1 di 1
    • Disconnect the battery terminal wires and the play, pause, and stop wires from the motherboard.
  4. Amazon Fire Game Controller Motherboard Replacement: passo 4, immagine 1 di 1
    • Use a J1 screwdriver to unscrew the four 7 mm screws from the motherboard.
  5. Amazon Fire Game Controller Motherboard Replacement: passo 5, immagine 1 di 1
    • Lift the motherboard out of the controller casing.
Conclusione
IUPUI, Team S4-G4, Wilson Summer 2019 Membro di IUPUI, Team S4-G4, Wilson Summer 2019
IUPUI-WILSON-SU19S4G4
4 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 780
