Salta al contenuto principale
Amazon Echo Tweeter Replacement
Cosa ti serve
  1. Amazon Echo Tweeter Replacement, Power and Speaker Driver Board: passo 1, immagine 1 di 1
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Tweeter Replacement: passo 2, immagine 1 di 3 Amazon Echo Tweeter Replacement: passo 2, immagine 2 di 3 Amazon Echo Tweeter Replacement: passo 2, immagine 3 di 3
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Tweeter Replacement: passo 3, immagine 1 di 1
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Tweeter Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo Tweeter Replacement: passo 5, immagine 1 di 2 Amazon Echo Tweeter Replacement: passo 5, immagine 2 di 2
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Tweeter Replacement: passo 6, immagine 1 di 3 Amazon Echo Tweeter Replacement: passo 6, immagine 2 di 3 Amazon Echo Tweeter Replacement: passo 6, immagine 3 di 3
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
  7. Amazon Echo Tweeter Replacement, Tweeter Assembly: passo 7, immagine 1 di 2 Amazon Echo Tweeter Replacement, Tweeter Assembly: passo 7, immagine 2 di 2
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
  8. Amazon Echo Tweeter Replacement: passo 8, immagine 1 di 1
    • Peel off the black fabric wrapped around the Echo.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
  9. Amazon Echo Tweeter Replacement: passo 9, immagine 1 di 3 Amazon Echo Tweeter Replacement: passo 9, immagine 2 di 3 Amazon Echo Tweeter Replacement: passo 9, immagine 3 di 3
    • Remove the four 42.8 mm T10 Torx screws around the tweeter.
    • Lift the tweeter and its attached housing from the device.
  10. Amazon Echo Tweeter Replacement, Tweeter: passo 10, immagine 1 di 2 Amazon Echo Tweeter Replacement, Tweeter: passo 10, immagine 2 di 2
    • Using a spudger or your fingers, pull back the plastic clips near the edge of the tweeter.
    • Remove the tweeter from its plastic housing.
Conclusione
Alexander Albert
Membro da: 02/04/16
1.169 Reputazione
6 Guide realizzate
3Commenti sulla guida
Anyone know where to get a replacement tweeter?
Ryan Alexander - Replica
Could you kindly post the dimension and depth of this tweeter/full range unit? Thank you.
No Body - Replica
Can anyone provide me the spare tweeter of Amazon echo dot 3rd generation
Pravesh Bansal - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 25
Tutti i Tempi: 6,358
