Salta al contenuto principale
Amazon Echo Studio Tweeter Replacement
Cosa ti serve
  1. Amazon Echo Studio Tweeter Replacement, Power Supply Board: passo 1, immagine 1 di 3 Amazon Echo Studio Tweeter Replacement, Power Supply Board: passo 1, immagine 2 di 3 Amazon Echo Studio Tweeter Replacement, Power Supply Board: passo 1, immagine 3 di 3
    • Flip the device upside down.
    • Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
  2. Amazon Echo Studio Tweeter Replacement: passo 2, immagine 1 di 3 Amazon Echo Studio Tweeter Replacement: passo 2, immagine 2 di 3 Amazon Echo Studio Tweeter Replacement: passo 2, immagine 3 di 3
    • Use a T15 Torx screwdriver to remove the nine 3.2 mm screws.
    • Use a Torx T10 screwdriver to remove the six 2.7 mm screws.
    • After removing the screws, gently lift the base off, with care not to damage any of the connected cables.
  3. Amazon Echo Studio Tweeter Replacement: passo 3, immagine 1 di 3 Amazon Echo Studio Tweeter Replacement: passo 3, immagine 2 di 3 Amazon Echo Studio Tweeter Replacement: passo 3, immagine 3 di 3
    • Before fully removing the base, remove the three attached connectors.
  4. Amazon Echo Studio Tweeter Replacement: passo 4, immagine 1 di 2 Amazon Echo Studio Tweeter Replacement: passo 4, immagine 2 di 2
    • Now unscrew the the single 10 mm Phillips screw.
    • Remove the power supply board.
  5. Amazon Echo Studio Tweeter Replacement, Subwoofer: passo 5, immagine 1 di 1
    • Remove the two screws located across from each other on the outside of the plastic ring shown.
    • Remove the plastic outer ring that hugs the inside of the edges of the device.
    • This may require you to use a soft prying tool to separate it from the outer shell.
  6. Amazon Echo Studio Tweeter Replacement: passo 6, immagine 1 di 3 Amazon Echo Studio Tweeter Replacement: passo 6, immagine 2 di 3 Amazon Echo Studio Tweeter Replacement: passo 6, immagine 3 di 3
    • Remove the two 2.7 mm screws with a T10 Torx screwdriver.
    • Once the screws are removed, take the power supply's baseplate out of the unit.
    • You may need to gently pry the subwoofer's air ports from the round slots In the side of the unit.
  7. Amazon Echo Studio Tweeter Replacement: passo 7, immagine 1 di 2 Amazon Echo Studio Tweeter Replacement: passo 7, immagine 2 di 2
    • On the silver ring located on the outer edge of the plastic portion of the subwoofer, you will see four 2.7 mm screws. Use a Torx T10 screwdriver to remove them, in order to remove of the subwoofer.
    • Once the four screws have been removed, gently pull the subwoofer out as to not damage the wiring connecting the subwoofer to the main board inside the unit.
    • Follow the wires from the subwoofer to the main board and disconnect the connector attaching them.
    • Your subwoofer is now disconnected and ready to be replaced.
  8. Amazon Echo Studio Tweeter Replacement, Motherboard: passo 8, immagine 1 di 2 Amazon Echo Studio Tweeter Replacement, Motherboard: passo 8, immagine 2 di 2
    • Remove the thirteen 9 mm Phillips #00 screws.
    • Some screws may be hidden by other components; simply hold them out of your way during screw removal.
  9. Amazon Echo Studio Tweeter Replacement: passo 9, immagine 1 di 1
    • Unfasten the Phillips 9mm screws, using the Phillips #00 Screwdriver.
    • There may be obstruction against some screws, which can be avoided by using a spudger or your hand.
  10. Amazon Echo Studio Tweeter Replacement: passo 10, immagine 1 di 3 Amazon Echo Studio Tweeter Replacement: passo 10, immagine 2 di 3 Amazon Echo Studio Tweeter Replacement: passo 10, immagine 3 di 3
    • After removing the screws, locate the four power connectors on the motherboard and detach them from the motherboard.
  11. Amazon Echo Studio Tweeter Replacement: passo 11, immagine 1 di 1
    • Remove the motherboard from the device by pulling it out.
    • Be careful to not damage any of the loose wires inside the case while removing the motherboard.
  12. Amazon Echo Studio Tweeter Replacement, Light Board: passo 12, immagine 1 di 3 Amazon Echo Studio Tweeter Replacement, Light Board: passo 12, immagine 2 di 3 Amazon Echo Studio Tweeter Replacement, Light Board: passo 12, immagine 3 di 3
    • First, locate the six 10 mm screws at the top of the inside of the shell and unscrew them with a T10 Torx screwdriver.
    • After removing the six screws from the inside, lift the top speaker cover.
  13. Amazon Echo Studio Tweeter Replacement: passo 13, immagine 1 di 3 Amazon Echo Studio Tweeter Replacement: passo 13, immagine 2 di 3 Amazon Echo Studio Tweeter Replacement: passo 13, immagine 3 di 3
    • Lift the top plastic cover that has the buttons.
    • If you feel a lot of resistance while removing this piece, check if you removed every screw from the inside or you risk breaking this part.
  14. Amazon Echo Studio Tweeter Replacement: passo 14, immagine 1 di 3 Amazon Echo Studio Tweeter Replacement: passo 14, immagine 2 di 3 Amazon Echo Studio Tweeter Replacement: passo 14, immagine 3 di 3
    • After the screws are removed, carefully lift the lightboard and disconnect the ribbon.
    • Make sure you do not forget to detach the ribbon from the shell, or you risk breaking it.
  15. Amazon Echo Studio Tweeter Replacement, Tweeter: passo 15, immagine 1 di 3 Amazon Echo Studio Tweeter Replacement, Tweeter: passo 15, immagine 2 di 3 Amazon Echo Studio Tweeter Replacement, Tweeter: passo 15, immagine 3 di 3
    • Remove the four 3.27 mm screws with T15 Torx driver.
    • After removing the screws, push/pull the inner shell out of the outer shell.
    • You might need someone's help to remove the inside shell, because it is very tight inside the outer shell.
  16. Amazon Echo Studio Tweeter Replacement: passo 16, immagine 1 di 3 Amazon Echo Studio Tweeter Replacement: passo 16, immagine 2 di 3 Amazon Echo Studio Tweeter Replacement: passo 16, immagine 3 di 3
    • Remove the wire from its slot inside the shell so the tweeter can be removed.
    • Unscrew the two 3.2 mm screws holding the tweeter in place with a T15 Torx screwdriver.
    • Pull the tweeter out.
Conclusione
UMass Dartmouth, Team 2-6, Petersen Fall 2022 Membro di UMass Dartmouth, Team 2-6, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G6
4 Membri
7 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 435
