Salta al contenuto principale
Amazon Echo Studio Subwoofer Replacement
Cosa ti serve
  1. Amazon Echo Studio Subwoofer Replacement, Power Supply Board: passo 1, immagine 1 di 3 Amazon Echo Studio Subwoofer Replacement, Power Supply Board: passo 1, immagine 2 di 3 Amazon Echo Studio Subwoofer Replacement, Power Supply Board: passo 1, immagine 3 di 3
    • Flip the device upside down.
    • Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
  2. Amazon Echo Studio Subwoofer Replacement: passo 2, immagine 1 di 3 Amazon Echo Studio Subwoofer Replacement: passo 2, immagine 2 di 3 Amazon Echo Studio Subwoofer Replacement: passo 2, immagine 3 di 3
    • Use a T15 Torx screwdriver to remove the nine 3.2 mm screws.
    • Use a Torx T10 screwdriver to remove the six 2.7 mm screws.
    • After removing the screws, gently lift the base off, with care not to damage any of the connected cables.
  3. Amazon Echo Studio Subwoofer Replacement: passo 3, immagine 1 di 3 Amazon Echo Studio Subwoofer Replacement: passo 3, immagine 2 di 3 Amazon Echo Studio Subwoofer Replacement: passo 3, immagine 3 di 3
    • Before fully removing the base, remove the three attached connectors.
  4. Amazon Echo Studio Subwoofer Replacement: passo 4, immagine 1 di 2 Amazon Echo Studio Subwoofer Replacement: passo 4, immagine 2 di 2
    • Now unscrew the the single 10 mm Phillips screw.
    • Remove the power supply board.
  5. Amazon Echo Studio Subwoofer Replacement, Subwoofer: passo 5, immagine 1 di 1
    • Remove the two screws located across from each other on the outside of the plastic ring shown.
    • Remove the plastic outer ring that hugs the inside of the edges of the device.
    • This may require you to use a soft prying tool to separate it from the outer shell.
  6. Amazon Echo Studio Subwoofer Replacement: passo 6, immagine 1 di 3 Amazon Echo Studio Subwoofer Replacement: passo 6, immagine 2 di 3 Amazon Echo Studio Subwoofer Replacement: passo 6, immagine 3 di 3
    • Remove the two 2.7 mm screws with a T10 Torx screwdriver.
    • Once the screws are removed, take the power supply's baseplate out of the unit.
    • You may need to gently pry the subwoofer's air ports from the round slots In the side of the unit.
  7. Amazon Echo Studio Subwoofer Replacement: passo 7, immagine 1 di 2 Amazon Echo Studio Subwoofer Replacement: passo 7, immagine 2 di 2
    • On the silver ring located on the outer edge of the plastic portion of the subwoofer, you will see four 2.7 mm screws. Use a Torx T10 screwdriver to remove them, in order to remove of the subwoofer.
    • Once the four screws have been removed, gently pull the subwoofer out as to not damage the wiring connecting the subwoofer to the main board inside the unit.
    • Follow the wires from the subwoofer to the main board and disconnect the connector attaching them.
    • Your subwoofer is now disconnected and ready to be replaced.
Conclusione
Jaiden Wiles
Membro da: 10/26/22
160 Reputazione
1 Guida realizzata
UMass Dartmouth, Team 2-6, Petersen Fall 2022 Membro di UMass Dartmouth, Team 2-6, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G6
4 Membri
7 Guide realizzate
1Commento della guida
Does anybody know where to get a replacement subwoofer?
Matthew Johnson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 43
Tutti i Tempi: 1,286
