Salta al contenuto principale
Amazon Echo Show 8 2nd Generation Rear Case Replacement
Cosa ti serve
  1. Amazon Echo Show 8 2nd Generation Rear Case Replacement, Rear Case: passo 1, immagine 1 di 3 Amazon Echo Show 8 2nd Generation Rear Case Replacement, Rear Case: passo 1, immagine 2 di 3 Amazon Echo Show 8 2nd Generation Rear Case Replacement, Rear Case: passo 1, immagine 3 di 3
    • Flip the device so that the rubber foot is facing up.
    • Insert a Jimmy between the rubber foot and chassis, then slide it around the perimeter until the rubber foot releases.
    • The adhesive that holds the rubber mat on may require some force to sever.
    • Remove the rubber foot.
  2. Amazon Echo Show 8 2nd Generation Rear Case Replacement: passo 2, immagine 1 di 3 Amazon Echo Show 8 2nd Generation Rear Case Replacement: passo 2, immagine 2 di 3 Amazon Echo Show 8 2nd Generation Rear Case Replacement: passo 2, immagine 3 di 3
    • Use a T6 Torx screwdriver to remove the five 4.5 mm screws from the base of the device.
  3. Amazon Echo Show 8 2nd Generation Rear Case Replacement: passo 3, immagine 1 di 3 Amazon Echo Show 8 2nd Generation Rear Case Replacement: passo 3, immagine 2 di 3 Amazon Echo Show 8 2nd Generation Rear Case Replacement: passo 3, immagine 3 di 3
    • Insert a Jimmy in the gap between the front and rear case.
    • Work the Jimmy around the perimeter to gently detach the rear case from the front case.
    • Separate the rear case from the front case.
    • There are 2 thin ribbon cables connecting the microphone board to the back cover. Take care not to tear or strain them as you separate the cases.
  4. Amazon Echo Show 8 2nd Generation Rear Case Replacement: passo 4, immagine 1 di 3 Amazon Echo Show 8 2nd Generation Rear Case Replacement: passo 4, immagine 2 di 3 Amazon Echo Show 8 2nd Generation Rear Case Replacement: passo 4, immagine 3 di 3
    • Use a T6 Torx screwdriver to remove the four 5.2 mm screws that secure the microphone board to the rear case.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 73
