Introduzione
Follow this guide to replace the Amazon Echo Show microphone. The microphone of the Amazon Echo Show is responsible for picking up audio signals. Replacement requires precision and patience, especially when working with small screws and fragile ribbon connectors.
Cosa ti serve
Orient the Amazon Echo Show 5 so that the display is face down.
Use a spudger to remove the grey bottom cover.
Remove the red and black power connector connecting to the motherboard with either a prying tool or your hands.
Use the Philips #000 Screwdriver to remove two 4mm screws that hold down the metal bracket.
Use tweezers to remove the metal bracket by lifting it up and towards yourself.
