Salta al contenuto principale
Amazon Echo Show 15 Motherboard Replacement
Cosa ti serve
  1. Amazon Echo Show 15 Motherboard Replacement, Back Panel: passo 1, immagine 1 di 3 Amazon Echo Show 15 Motherboard Replacement, Back Panel: passo 1, immagine 2 di 3 Amazon Echo Show 15 Motherboard Replacement, Back Panel: passo 1, immagine 3 di 3
    • Remove the four white stickers on your device's back panel.
    • Due to the strong adhesive supporting the stickers, we recommend heating them up to make removal easier.
    • A hair dryer may work best for this step.
  2. Amazon Echo Show 15 Motherboard Replacement: passo 2, immagine 1 di 3 Amazon Echo Show 15 Motherboard Replacement: passo 2, immagine 2 di 3 Amazon Echo Show 15 Motherboard Replacement: passo 2, immagine 3 di 3
    • Unscrew the four 50 mm screws with a T3 Torx screwdriver.
    • Pop the sides and remove the back panel of the device.
  3. Amazon Echo Show 15 Motherboard Replacement, Motherboard: passo 3, immagine 1 di 3 Amazon Echo Show 15 Motherboard Replacement, Motherboard: passo 3, immagine 2 di 3 Amazon Echo Show 15 Motherboard Replacement, Motherboard: passo 3, immagine 3 di 3
    • Remove the five 3 mm screws from the metal protector using a Torx T5 screwdriver.
    • Take off the metal protector.
    • The metal protector is connected to the motherboard with adhesive. More force may be necessary.
    • Remove the twelve 3 mm screws from the motherboard using the Torx T5 screwdriver.
  4. Amazon Echo Show 15 Motherboard Replacement: passo 4, immagine 1 di 3 Amazon Echo Show 15 Motherboard Replacement: passo 4, immagine 2 di 3 Amazon Echo Show 15 Motherboard Replacement: passo 4, immagine 3 di 3
    • Detach the connectors for the camera and buttons from the motherboard.
    • Detach the connectors for the power station and speakers from the motherboard.
    • Detach the small white coaxial cables from the motherboard.
    • These connectors will be reused, so be very careful with them. The small white connectors come off by being pulled up.
  5. Amazon Echo Show 15 Motherboard Replacement: passo 5, immagine 1 di 1
    • Remove the motherboard from the main device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 40
Tutti i Tempi: 260
