Salta al contenuto principale
Amazon Echo Show 15 Inner Black Panel Replacement
Cosa ti serve
  1. Amazon Echo Show 15 Inner Black Panel Replacement, Back Panel: passo 1, immagine 1 di 3 Amazon Echo Show 15 Inner Black Panel Replacement, Back Panel: passo 1, immagine 2 di 3 Amazon Echo Show 15 Inner Black Panel Replacement, Back Panel: passo 1, immagine 3 di 3
    • Remove the four white stickers on your device's back panel.
    • Due to the strong adhesive supporting the stickers, we recommend heating them up to make removal easier.
    • A hair dryer may work best for this step.
  2. Amazon Echo Show 15 Inner Black Panel Replacement: passo 2, immagine 1 di 3 Amazon Echo Show 15 Inner Black Panel Replacement: passo 2, immagine 2 di 3 Amazon Echo Show 15 Inner Black Panel Replacement: passo 2, immagine 3 di 3
    • Unscrew the four 50 mm screws with a T3 Torx screwdriver.
    • Pop the sides and remove the back panel of the device.
  3. Amazon Echo Show 15 Inner Black Panel Replacement, Inner Black Panel: passo 3, immagine 1 di 3 Amazon Echo Show 15 Inner Black Panel Replacement, Inner Black Panel: passo 3, immagine 2 di 3 Amazon Echo Show 15 Inner Black Panel Replacement, Inner Black Panel: passo 3, immagine 3 di 3
    • In the top right corner you will find a small black panel.
    • Remove the five 2 mm screws with a Torx T5 screwdriver.
    • Remove the two 5 mm with a Torx T3 screwdriver.
    • Remove both ends of the connector from the main device.
    • Remove the black panel.
Conclusione
Talara
Membro da: 09/20/23
306 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 18
Tutti i Tempi: 95
