Salta al contenuto principale
Amazon Echo Power and Speaker Driver Board Replacement
Cosa ti serve
  1. Amazon Echo Power and Speaker Driver Board Replacement, Power and Speaker Driver Board: passo 1, immagine 1 di 1
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Power and Speaker Driver Board Replacement: passo 2, immagine 1 di 3 Amazon Echo Power and Speaker Driver Board Replacement: passo 2, immagine 2 di 3 Amazon Echo Power and Speaker Driver Board Replacement: passo 2, immagine 3 di 3
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Power and Speaker Driver Board Replacement: passo 3, immagine 1 di 1
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Power and Speaker Driver Board Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo Power and Speaker Driver Board Replacement: passo 5, immagine 1 di 2 Amazon Echo Power and Speaker Driver Board Replacement: passo 5, immagine 2 di 2
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Power and Speaker Driver Board Replacement: passo 6, immagine 1 di 3 Amazon Echo Power and Speaker Driver Board Replacement: passo 6, immagine 2 di 3 Amazon Echo Power and Speaker Driver Board Replacement: passo 6, immagine 3 di 3
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
Conclusione
Altre 10 persone hanno completato questa guida.
USF Tampa, Team 3-3, Wollert Spring 2016 Membro di USF Tampa, Team 3-3, Wollert Spring 2016
USFT-WOLLERT-S16S3G3
4 Membri
12 Guide realizzate
22Commenti sulla guida
It's great that you have provided these instructions. I need to do this with mine. Do you know where I can get a replacement board?
Taylor Wolf - Replica
Taylor, did you ever find a new board? I need one too.
Mark Hall -
Great instructions BUT ...... THERE IS NO PLACE TO BUY THE BOARD!! (It's proprietary to Amazon) So this instruction is about as useful as jumping out of a plane before asking for a parachute.
blueskymining -
same here...
D Nation - Replica
Where do I get a replacement board ?
Sean Burch - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 136
Tutti i Tempi: 28,429
