Salta al contenuto principale
Amazon Echo Motherboard Replacement
Cosa ti serve
  1. Amazon Echo Motherboard Replacement, Power and Speaker Driver Board: passo 1, immagine 1 di 1
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Motherboard Replacement: passo 2, immagine 1 di 3 Amazon Echo Motherboard Replacement: passo 2, immagine 2 di 3 Amazon Echo Motherboard Replacement: passo 2, immagine 3 di 3
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Motherboard Replacement: passo 3, immagine 1 di 1
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Motherboard Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo Motherboard Replacement: passo 5, immagine 1 di 2 Amazon Echo Motherboard Replacement: passo 5, immagine 2 di 2
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Motherboard Replacement: passo 6, immagine 1 di 3 Amazon Echo Motherboard Replacement: passo 6, immagine 2 di 3 Amazon Echo Motherboard Replacement: passo 6, immagine 3 di 3
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
  7. Amazon Echo Motherboard Replacement, Motherboard: passo 7, immagine 1 di 2 Amazon Echo Motherboard Replacement, Motherboard: passo 7, immagine 2 di 2
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
  8. Amazon Echo Motherboard Replacement: passo 8, immagine 1 di 1
    • Peel off the black fabric wrapped around the device.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
  9. Amazon Echo Motherboard Replacement: passo 9, immagine 1 di 2 Amazon Echo Motherboard Replacement: passo 9, immagine 2 di 2
    • Remove the four 9.7 mm T10 screws.
  10. Amazon Echo Motherboard Replacement: passo 10, immagine 1 di 3 Amazon Echo Motherboard Replacement: passo 10, immagine 2 di 3 Amazon Echo Motherboard Replacement: passo 10, immagine 3 di 3
    • Lift the brown and black plastic latches securing the ZIF connectors at each end of the motherboard.
    • Pull the two ribbon cables from their connectors on the motherboard.
  11. Amazon Echo Motherboard Replacement: passo 11, immagine 1 di 1
    • Lift the motherboard up from the Echo.
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team 3-3, Wollert Spring 2016 Membro di USF Tampa, Team 3-3, Wollert Spring 2016
USFT-WOLLERT-S16S3G3
4 Membri
12 Guide realizzate
11 Commenti
Where can you get the mmotherboard
Glen Seay - Replica
same question. where do i get replacement motherboard?
akn978s - Replica
This is how to remove the motherboard not how to replace it....geez
adairt - Replica
There is a reason why people look for information on how to remove it; and that is … TO REPLACE IT! So, where can you get a replacement?
arcsnsparks2000 - Replica
So no place to buy the motherboard, iv striped it down but can’t buy the board anywhere
mark crewe - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 73
Tutti i Tempi: 14,830
