Salta al contenuto principale
Amazon Echo Look Wi-Fi Module Replacement
Cosa ti serve
  1. Amazon Echo Look Wi-Fi Module Replacement, Front Panel: passo 1, immagine 1 di 1
    • Ensure the device is completely powered off and disconnected from any power source by removing the charger adapter point from the back of the device.
  2. Amazon Echo Look Wi-Fi Module Replacement: passo 2, immagine 1 di 3 Amazon Echo Look Wi-Fi Module Replacement: passo 2, immagine 2 di 3 Amazon Echo Look Wi-Fi Module Replacement: passo 2, immagine 3 di 3
    • If the device stand is attached, remove it by twisting the device's base toward yourself until detached.
  3. Amazon Echo Look Wi-Fi Module Replacement: passo 3, immagine 1 di 1
    • Heat the front panel with an iOpener.
    • It may help to secure the iOpener to the device.
    • Heat the device for 5-10 minutes to loosen the glue.
    • CAUTION: The iOpener and the device may be hot.
  4. Amazon Echo Look Wi-Fi Module Replacement: passo 4, immagine 1 di 3 Amazon Echo Look Wi-Fi Module Replacement: passo 4, immagine 2 di 3 Amazon Echo Look Wi-Fi Module Replacement: passo 4, immagine 3 di 3
    • Lever the Jimmy between the screen and the device until an opening is formed.
    • Insert opening picks to hold the opening as needed.
    • Use a spudger to circle the border of the front panel and disconnect any lingering glue.
    • Step 3 may need to be repeated as Step 4 is time-sensitive.
  5. Amazon Echo Look Wi-Fi Module Replacement: passo 5, immagine 1 di 2 Amazon Echo Look Wi-Fi Module Replacement: passo 5, immagine 2 di 2
    • Remove the front panel by levering the spudger at the top of the device.
  6. Amazon Echo Look Wi-Fi Module Replacement, Midframe: passo 6, immagine 1 di 2 Amazon Echo Look Wi-Fi Module Replacement, Midframe: passo 6, immagine 2 di 2
    • Remove the screws from the midframe with a Torx T5 screwdriver.
    • Lift up the midframe
    • Remove the eight screws attached to the gray metal piece using a Torx T5 screwdriver.
  7. Amazon Echo Look Wi-Fi Module Replacement: passo 7, immagine 1 di 2 Amazon Echo Look Wi-Fi Module Replacement: passo 7, immagine 2 di 2
    • Use a spudger to gently lift up the ribbon until it detaches.
  8. Amazon Echo Look Wi-Fi Module Replacement, Wi-Fi Module: passo 8, immagine 1 di 1
    • Use a spudger to pry the Wi-Fi module away from the motherboard.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 30
Tutti i Tempi: 205
