Introduzione
The smaller of the PCB's in the Amazon Echo Dot is used to coordinate the button functions. Removing it is very simple but can be a bit tricky due to the method of removal. The screws holding in the PCB are very small so it is recommended that extra care is taken when replacing this component.
Cosa ti serve
Using a spudger, remove the rubber footing around the base of the Echo Dot. This will reveal the four T8 1.25 cm Torx screws.
Now, use a plastic prying tool to remove the ribbon cable from the speaker housing.
Remove the upper switch PCB using the T4 Torx bit to unscrew the four 5 mm screws.
Push down on the buttons through the top of the case and pry lightly with plastic tools until loose, then remove.
