Salta al contenuto principale
Amazon Echo Dot 5th Generation Speaker Replacement
Cosa ti serve
  1. Amazon Echo Dot 5th Generation Speaker Replacement, Motherboard: passo 1, immagine 1 di 2 Amazon Echo Dot 5th Generation Speaker Replacement, Motherboard: passo 1, immagine 2 di 2
    • Using a spudger, remove the rubber footing around the base of the Echo Dot. This will reveal the four T8 1.25 cm Torx screws.
  2. Amazon Echo Dot 5th Generation Speaker Replacement: passo 2, immagine 1 di 1
    • Once removed, the Echo Dot is now able to be split in two.
    • The ribbon cable connecting the microphone to the CPU PCB is now exposed, be careful not to tear it. The lower case will have the LED diffuser along the bottom, while the upper case will contain the rest of the internals.
  3. Amazon Echo Dot 5th Generation Speaker Replacement: passo 3, immagine 1 di 3 Amazon Echo Dot 5th Generation Speaker Replacement: passo 3, immagine 2 di 3 Amazon Echo Dot 5th Generation Speaker Replacement: passo 3, immagine 3 di 3
    • Remove the CPU PCB by removing the 4 T6 0.75cm Torx screws.
    • Once removed, unclip the plastic retainer on the CPU PCB and slide the ribbon cable out. This will reveal the speaker’s metal housing.
  4. Amazon Echo Dot 5th Generation Speaker Replacement, Speaker: passo 4, immagine 1 di 1
    • To access the speaker, take a plastic spudger and slowly lift the ribbon off of the housing.
    • Remove the four T8 1cm Torx screws around the edges of the metal housing.
    • Lift the top case off of the housing to reveal the speaker.
  5. Amazon Echo Dot 5th Generation Speaker Replacement: passo 5, immagine 1 di 1
    • Using a Torx T5 bit, remove the four 1cm screws around the speaker and slide it out of the housing.
    • Pull 2 speaker cables off of the speaker and detach it.
Conclusione
Madison Dufault
Membro da: 10/30/23
112 Reputazione
1 Guida realizzata
UMass Dartmouth, Team 3-4, Konn Fall 2023 Membro di UMass Dartmouth, Team 3-4, Konn Fall 2023
UMASSD-KONN-F23S3G4
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 57
Tutti i Tempi: 274
