Salta al contenuto principale
Amazon Echo Dot 5th Generation Motherboard Replacement
Cosa ti serve
  1. Amazon Echo Dot 5th Generation Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 Amazon Echo Dot 5th Generation Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Using a spudger, remove the rubber footing around the base of the Echo Dot. This will reveal the four T8 1.25 cm Torx screws.
  2. Amazon Echo Dot 5th Generation Motherboard Replacement: passo 2, immagine 1 di 1
    • Once removed, the Echo Dot is now able to be split in two.
    • The ribbon cable connecting the microphone to the CPU PCB is now exposed, be careful not to tear it. The lower case will have the LED diffuser along the bottom, while the upper case will contain the rest of the internals.
  3. Amazon Echo Dot 5th Generation Motherboard Replacement: passo 3, immagine 1 di 3 Amazon Echo Dot 5th Generation Motherboard Replacement: passo 3, immagine 2 di 3 Amazon Echo Dot 5th Generation Motherboard Replacement: passo 3, immagine 3 di 3
    • Remove the CPU PCB by removing the 4 T6 0.75cm Torx screws.
    • Once removed, unclip the plastic retainer on the CPU PCB and slide the ribbon cable out. This will reveal the speaker’s metal housing.
Conclusione
Grace Warila
Membro da: 10/30/23
197 Reputazione
1 Guida realizzata
UMass Dartmouth, Team 3-4, Konn Fall 2023 Membro di UMass Dartmouth, Team 3-4, Konn Fall 2023
UMASSD-KONN-F23S3G4
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 36
Tutti i Tempi: 179
