Salta al contenuto principale
Introduzione
Use this guide to replace the ribbon cable in the Amazon Echo Dot 2nd Generation.
  1. Power off and unplug the echo Using the plastic opening tool, peel off the rubber layer on the bottom of the echo Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
  2. Use a T8 screwdriver bit to unscrew the 1.6mm four screws. Remove the black cylindrical base Remove the black cylindrical base
    • Use a T8 screwdriver bit to unscrew the 1.6mm four screws.
    • Remove the black cylindrical base
  3. Use the metal spudger to lift the ZIF connector Remove the ribbon cable from the slot Remove the ribbon cable from the slot
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
  4. Remove the motherboard
    • Remove the motherboard
  5. Remove the silver divider Remove the black rubber divider Remove the plastic white frame
    • Remove the silver divider
    • Remove the black rubber divider
    • Remove the plastic white frame
  6. Use the metal spudger to lift the ZIF connector Remove the ribbon cable from the slot on the LED/speaker board Remove the ribbon cable from the slot on the LED/speaker board
    • Remove the ribbon cable from the slot on the LED/speaker board
Conclusione
Errica Snelling
Membro da: 09/10/2017
356 Reputazione
1 Guida realizzata
USF Tampa, Team S1-G3, Leahy Fall 2017 Membro di USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
3 Membri
10 Guide realizzate
Where do you get the replacement cable from?
jonathan kabitzke - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 30
Tutti i Tempi: 798
