Salta al contenuto principale
Amazon Echo Dot 2nd Generation Ribbon Cable Replacement
Cosa ti serve
  1. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: passo 1, immagine 1 di 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: passo 1, immagine 2 di 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: passo 1, immagine 3 di 3
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
  2. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 2, immagine 1 di 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 2, immagine 2 di 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 2, immagine 3 di 3
    • Use a T8 screwdriver bit to unscrew the 1.6mm four screws.
    • Remove the black cylindrical base
  3. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 3, immagine 1 di 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 3, immagine 2 di 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 3, immagine 3 di 3
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
  4. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 4, immagine 1 di 1
    • Remove the motherboard
  5. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 5, immagine 1 di 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 5, immagine 2 di 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 5, immagine 3 di 3
    • Remove the silver divider
    • Remove the black rubber divider
    • Remove the plastic white frame
  6. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 6, immagine 1 di 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 6, immagine 2 di 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 6, immagine 3 di 3
    • Remove the ribbon cable from the slot on the LED/speaker board
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team S1-G3, Leahy Fall 2017 Membro di USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
3 Membri
12 Guide realizzate
5 Commenti
Where do you get the replacement cable from?
jonathan kabitzke - Replica
Yes, where can one get replacement ribbon cables?
Armando Morreale - Replica
Malcolm oakley - Replica
I need a replacement as well now was using a pointed tweezers when putting it back together and stabbed the cable need to find part and order from the uk
Barrie Gash - Replica
no cable available, just waiting for donors
Ray Floyd Cabrera - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 25
Tutti i Tempi: 2,258
